flex fuel sensor malfunction?
00stranger
Winnipeg, Canada
3.0L flex
Sorry for bringing up a old thread but hopefully this will help somebody.
I fixed my problem by installing a flex fuel replicator from pointaengineering.com. It already had the ford connector on it so it only took a few minutes to install. After years of occasionally pulling over to reset my computer, I haven't had a problem since. I installed it around a year ago
rwf32
Did you fix? If so How?
I'm suffering from similiar incidents! I've posted in another thread trying to get an answer! I'll copy paste it below my question. But I've gotta ask if you ever fixed your issue and if so how?
(ORIGINAL QUESTION ON ANOTHER THREAD)
First off I'm by no means a mechanic, hence why I am here! My truck is a 2000 Ford Ranger XLT 4wd v6 3.0 Flex I am running 87 Octane in it however!
My problems started off by the vehicle sputtering and puttering one day not long after I got gas, thought I just got water in the tank? It died on me and my buddy showed me a trick by taking the neg. off the battery terminal and leaving that for a few minutes to reset it or something. Well that worked so I went and put some ISO HEET in the gas to try and treat the (WATER?) and put some fuel treatment in it. Well that didn't work. after the thing dying over and over after driving for a day and the only thing getting it to run again is by reseting cpu by removing the neg battery terminal for about 2 minutes. I got a couple local opinions and they said bad fuel pump. So I replaced the fuel pump, and fuel filter.
That got it it running again fine for two tanks of fuel no problem. Well just before filling up the tank again at tank #3 after new fuel pump boom! Same problem I'm back to square one!
I took the truck and borrowed a code reader at local parts store that read error p0176. I think I found the part but it's like 500 bucks... Any clue's? Any hints? Any Help, PLEASE! BTW Examples, videos or something would be great as I am stupid when it comes to vehicles! Yes I replaced the fuel pump but it was at the aid of youtube videos ha!
God bless and thank you~
bobbie58
9
bentleyville pa
flex fuel problem
I bought a 2000 ford ranger xlt (flex fuel ) from my neighbor who forgot to tell me the check engine light was on because of the flex fuel , so I bought a flex fuel replicator after putting it on and putting 250 miles on the truck to clear the code , it passed pa s state emissions test and my check engine light hasn't come back on and it runs better and the local parts store wanted $750 for a replacement flex fuel sensor, my replicator was $168
