Flared out ball joint dust boots
Patrick
Mazda
Hello all. First post here. I have a situation where my upper and lower ball joint dust boots are flared out toward the bottom. This has only occurred on the passenger's side for some reason. Do I need to pull these off and replace the dust boots, or is regular grease pumping good enough to keep the grime and dirt out? The joints are less than a year old (never buying Raybestos again!).
I'll try to include some pictures here. I would appreciate any suggestions. Also, how many times can one replace ball joints? I made the mistake of choosing the splined ones...
Vehicle: 1994 Mazda B3000, 2wd
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I'm not sure that I am seeing any sort of problem in your pictures (dust boots are designed to allow grease to escape, are they cracked or something?).
Got a pic of the driverside as a comparison?
Patrick
Mazda
Drivers side below. On the passenger side, the bottom of the boots aren't seated in their spots. It's like they are stretched out.
Sent from my Nexus 6P using Tapatalk
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I suspect that if you were to pump enough grease into the other side to fully fill the boot it will probably expand out in a similar manner. After some driving around it could actually contract a little as more grease escapes.
I don't think that it's an issue. As long as the joint stays greased it should be fine.
Welcome to TRS, by the way.
:beer:
Patrick
Mazda
Thanks for the welcome.
I've been driving around on the joints for a good 4-5 months after installation. Maybe my initial greasing pressurized them too much. There is some amount of surface cracking, as well. I chock it up to cheap rubber. Ill just keep them greased until I put new springs then assess whether its worth it to pound out the spindle and replace the boots.
Thanks for the help!
