Finally, my official project truck
Jbrown1238
6
Largo, Fl
306
None
Yes,its a little to close for my comfort. Although this truck will be my everyday driver travel truck.. You know I'm hunting that low 11 second time slip .. It will happen just once.then it will never see the 'track'again"
What amazed me was when I set the mock up short block down in there.. Then bolted the transsmision up.. It did not squat one bit!
I know what you mean. You will find that the engine package doesn't seem to move much even under torque. I thought that with the clearance at the pan being so tight it would at some point make contact. I check mine from time to time and have not found any evidence that it has touched. I still plan to create a little more room when the engine comes out for the first time.
Junglejoe
66
Columbia Missouri
6.0
I now have the entire engine and trans bolted in. I have to say I am blown away. The truck did not squat 1 inch! I'm sure once I start driving it it will settle some , but still!
This is ONLY the mock up stage.. I'm just getting a feel of how this all works and where everything fits.
I do have a question. I'm using the entire expo harnesses including the charging system.. I've been reading and seen that the 5 wire round plug is where the two wires has to be moved for the Ac? I do not have the books ,doing all this off of reading on other swaps.
Can someone verify if that is the case?
I can't post any more pics right now..says over the limit.
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
Solenoid wire plug
This plug is right underneath the lines that come off the abs.
The explorer and the ranger plug do not match up. (I think they were both male)
The Ranger plug has 5 wires
Yellow/white strip (Starter solenoid wire)
Red/yellow strip (signal wire high/low pressure a/c switch)
Black-white strip (ground for high/low pressure a/c switch)
Gray/white stripe(a/c clutch relay signal wire)
Black wire(a/c clutch relay ground wire)
Explorer plug has 3 wires
The reason the other two are not in there is because they come out by the radiator. So just wire up the 3 wire plug from the explorer and your good to go.
Junglejoe
66
Columbia Missouri
6.0
Thanks bro.. Appreciate it.
Craig0320
225
Mississppi
Jbrown1238
6
Largo, Fl
306
None
Funny you say that about the weight. I have not put the 99 Ranger on the scale but my 93 V8 Ranger had the same set up and it only gained 60 lbs with the swap over the 3.0 V6 5 speed. I put it on the scale at the Port of Tampa before and after the conversion. Since September 11, 2001 the Port of Tampa is no longer open to the general public.
Looks like Craig has you set up on the AC wires. Sounds pretty much like mine going from memory.
Junglejoe
66
Columbia Missouri
6.0
Thanks Jeff.. I'm a visual type..I kind of need to see it. Going off what Craig said
I think I know what to do..
But yes..on the fitment and the chassis compared to all off the s10's I've built over the years, the ranger is a lot better! When you drop a small block in an s10..you see it squat immediately!
Jbrown1238
6
Largo, Fl
306
None
I have had three sets of front springs in the 99 trying to get the height right where I wanted it. It always seems to settle about 1/2 inch over the first 90 days. Just set it up a little bit higher then you want.
Junglejoe
66
Columbia Missouri
6.0
Taking notes on that spring situation!
So..when I pulled the motor/trans out of the black 2000..I pulled the engine harness with it. No biggie..I have my white 99 to look over..
Well.. That plug for the starter and Ac is different between the to years.. One is just like the one Jeff pictures,on the 99 and the 2000 plug is more square. Same wires...just different plugs.
So now I just have solder couple more wires..no biggie!
Trucks are identicle with same options , the 99 is flex fuel only difference
Junglejoe
66
Columbia Missouri
6.0
Well after looking at the plugs again.. the 2000 has (2) big yellow wires.. I need to get a book I guess to seen what the wires go to.. have a look.
Dark photo is the 2000 ranger side of the plug
The other is the 99 side. .
Jbrown1238
6
Largo, Fl
306
None
Here is one more photo of the wiring I used from the Explorer Engine harness. I did need to splice in the small battery harness and the plug you mention above. That was all the main electrical modifications I remember. The Flex Fuel wiring was the same. The DTR Sensor and the O2's needed some changes but that is it.
Junglejoe
66
Columbia Missouri
6.0
Hmmm... On my plug, the 99 flex fuel has two yellow wires.. And a different style plug than my 2000 . Not sure why that it the case.
Appreciate the pics Bro!.
By the way, that is the exact battery harness I have from the donor.
Jbrown1238
6
Largo, Fl
306
None
I am pretty sure I didn't do anything with the Flex Fuel wiring except delete the Flex Fuel unit. I unplugged it under the driver seat on the exterior of the cab and replaced the section of fuel line from the filter forward with a OEM non Flex Fuel line from a salvage vehicle. If there were any unused wires I just capped them off or eliminated them all together.
