Fan shroud attachment
Denisefwd93
74
South East PA
Rained out again, so back online asking questions,
The bottom of the fan shroud is (4.0) flapping, . It appears to have tabs that tuck in the bottom of the radiator? Or i do I need some sort of bolts for sheet metal screws? Thank you?
There should be some little S clips that clip to the radiator and then those tabs sit in them.
Denisefwd93
74
South East PA
Thank you!
be like?
ericbphoto
Overlander in development
16,627
Wellford, SC
6"
yup. That's them.
Denisefwd93
74
South East PA
Thank you gentleman, I've been to the hardware and other stores about four times in the past few days I keep forgetting about these as clips.
So, himself was down here helping me pull the thermostat housing off... Never got to the rabs valve (maybe next week) Leaves saying "you can put it back it's only 3 bolts".
3 days later ... Another friend tells me, "just change the bolts to studs"
WAAAAA! Ok did that [emoji16] maybe three more days I'll get the nuts back on the three new studs. Guys, there be a big O ring around the thermostat! I did not expect that! I'm still thinking flat paper gasket!
Where do I find some slack in that wire harness that goes right in front of the bolt and flange? None on top.
