Factory radius arms
JerryC
56
Tennessee
2.9
My 88 has one that is a little chewed up from neglect by previous owners driving on a wiped out radius arm bushing.
Looking online I see 4wd RA's for 89 and up. Is there a difference with pre-88 and 89-up radius arms?
Thanks
alwaysFlOoReD
5,153
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I'm not a guru with this stuff. The physical mounting will be the same. Ranger 2wd and 4x4 don't interchange, the b2...don't know. The shock mounts changed somewhere in those years but I think the same shocks are used. I don't know about b2's, but there is a sway bar that mounts into the arms [maybe only 2wd ranger].
17,976
SW Iowa
Different shock mount. Newer mounts the shock on a stud older is incorporated into the sway bar bracket. I think they interchange but they are not the same.
JerryC
56
Tennessee
2.9
I should have noticed the shock mount, I looked at the picture probably a dozen times and I just replaced my shocks on my 88.
If that's the only difference, I'm good.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Yeah no problem. IMO the earlier design with the bracket is better, especially if you're in a rust-belt state, but either one will work (they are the same geometrically).
