F my life....
Swiftkid
Well guys i was going to replace my bearing and axel seals on my 89 Bronco II rear axel because one is leaking. After taking off the diff cover and trying to remove the 5/16 bolt that hold the spider gear pin in...i have failed. The bolt is pretty much seized up, i rounded the corners off and tried getting vice grips on it but even chewed it up more. Even got some special sockets that takes out messed up bolt heads but it chewed it up more. I'm gonna put the the diff cover back on and filler back up for now probaly drive it like that till it goes out. Any preferences on new rear ends that'll go right in after i pull out the old one this summer? What do you guys like for rear ends?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
most areas a working complete replacement rear diff is 100-250 bux.
take it to a shop with a torch and they can likely get it loose for a few bux as well...
06RangerXLT
54
Georgetown Ontario
mmm torch and diff fluid. lovely smell.
you could swap a 92 or earlier axle from a ranger, or find one from a bronco. may have the same problem though.
85_Ranger4x4
17,934
SW Iowa
Rangers have a different width between the spring perches and overall width. A straight Bronco would be very much different.
If you can't get the bolt out you will need one from another BII if you want a bolt in, if you want to get custom anything will work with varying amounts of effort.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
there is a slight difference in perch...never had an issue bolting them in. seen where some say it was...i have never had an issue...have to pry a bit to pop the pins in but the bolts cinch it down fine.:dunno:
problem was diff offset...b2 is more center
the ranger diff can cause exaust clearnace issue in b2
the b2 diff can cause gastank skid rub issue in certain ranger application. then there is the generational overall width and actual yoke/flange variances.
all easily navigated with oem parts.
best bet is b2 for b2 in any event.
CraigK
I'm not familiar with this bolt, but can you not drill it out?
CraigK
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
got any of these? i have a craftsman set and they've never let me down
CraigK
It's kind of a pain to drill the Jesus bolt. It sits below the level of the case and so it is really hard to put a drill on it.
F150hybred
Arborg Manitoba Canada
Last time I had an issue like this, all I did was get a drift and a BFH. Hit the spider pin with all you got and it will break the bolt. then you can remove the spider pin, axles... and then the carrier to gain access to the bolt.
No members online now.
