Explorer to Ranger?
93STX
Ohio
What all will go from an explorer into/onto a ranger? I have a '93 ex. cab 4.0 4wd. Thanks.
Sunk
125
Everett, WA
3.5 Eco
Depends what year Explorer.
93STX
Ohio
Idk I just wanna make it as nice as possible. I really wanna put a pair of black or gray leather seats in it. I read another post that said all the seats that'll go in, but I was wondering about suspension and what not. Like what upgrades I could do to it that wouldn't be ranger, something bigger/stronger.
Sunk
125
Everett, WA
3.5 Eco
You can swap in a 31 spline 8.8 rear end. Some even have disc brakes. It'll bolt in, but you'll need to move the spring mounts to the top of the axle and figure out shock mounts.
First Gen 4 dr Explorer seats will bolt right into an ext cab ranger.
Explorer leaf springs will give you about 1.5-2" of lift.
93STX
Ohio
what leafsprings would bolt right in? And would it have to be 4x4 leafs to give it a lift or would the 2wd ones work as well?
Sunk
125
Everett, WA
3.5 Eco
91-01 4 door explorer leafs. You want the packs with 4 leafs in them. Code F if that helps.
93STX
Ohio
Alright thanks. I'm going to the junkyard today so I'll check it out.
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
Are the 2 door Exploder sports a direct bolt in ? Why makes them not fit, if that IS the case?
