Explorer rear springs in BII
Jecsd1
Been reading and it seems that explorer springs are a direct swap other than turning the center pin upside down. The stock springs on my BII are sagging and looking pretty sorry.
When I go to the junk yard to pull some explorer springs should I be looking for any certain model? 2WD, 4WD, 2DR, 4DR, ETC....?
Thanks
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
4 door, 4x4. 2 door models mostly had the mono leaf. You can also use an 80's to 90's (pre 97) F150 leaf...
SVT
Jecsd1
SVT
Great info. I didn't realize F150 would work also. I appreciate the help.
Can I expect any lift out of some Ex springs? Other than from my sagging I mean.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Depending on how much sagging you had, usually about 1 to 1.5" are seen when swapping to ex leafs, results vary. You can take some of your old leafs and shuffle them into the ex leaf pack for more lift if thats what your after. I made a 6 leaf pack using stock 96 ranger and ex leafs giving me 3.5" lift...
SVT
Jecsd1
I'm not really after lift. Just want it back to stock height but if I get an inch or two that'll work also.
Thanks again.
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
My 84 B2 has the same problems, wondering if its worth the trouble. Also, if I do the leaf swap, would the vehicle need an alignment afterwards?
I'm guessing you would swap out one side at a time so an alignment wouldn't be needed as the axle would be in the same place it was before.
Jecsd1
As long as the centering pins are in good shape in the leaf springs I don't think there's any need for an alignment.
Wasp
North east
4XFORD
I went the other way and softened my springs then added air shocks designed for a Ranger to add height adjustability and flex. I like the fact I can adjust my load carrying buy adding or subtracting air pressure. I also found that heavier springs will eat up standard shocks.
