Electric Fan Kit?
Linus72
7
Orange, va
Mazda B3000
I've been trying to find a fan kit for my 1996 B3000 3.0 5speed.
Mostly for mpg increase etc.
I can find the fans but not a kit with on/off temp sensors etc plus the fan or fans?
Is there a plugNplay kit like that or I gotta piece it together myself?
Any help experience appreciated!
Thanks
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,532
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
One of our members @Rowdy Fitzgerald just bought a set up on eBay and he seems happy with it. Maybe he will chime in with a link... or you can search his build thread for th link.
Linus72
7
Orange, va
Mazda B3000
I wonder if it's this one?
Uncle Gump
Token Old Guy
13,532
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That is the one...
superj
2,659
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
I saved that for later
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
This is the kit I bought. I also installed an aftermarket, 4 core all aluminum radiator that was for an explorer. I have all of about 3/16” of clearance between the fan stud on the water pump and the electric fan. But it doesn’t rub and I have taken it through some rocky 4wd roads.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
650
Central Indiana
A fan without a shroud is not ideal. 01+ Duratec powered Rangers had factory Efans w/shroud that will bolt directly to other Ranger radiators:
Just get a temp sensor and wire it up following a basic guide and you'll have bolt in E fan with fully tested OEM functionality and quality.
Uncle Gump
Token Old Guy
13,532
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I've never been able to find CFM specs on that fan... it also isn't OEM quality.... it's Doorman. That system was also not a stand alone efan... it was used in conjunction with a clutch fan.
I'm not saying it wouldn't work though.
Uncle Gump
Token Old Guy
13,532
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Just to clarify... that Doorman efan was only found on 4cyl engines equipped with A/C. Which makes me believe it was more of a booster fan used for A/C. The same vehicle with that efan still uses a mechanical clutch fan to handle engine cooling. I simply question if it is enough to cool the engine standalone.
That is the one...
I looked at the seller name... it is the same seller as the link Rowdy posted. Although it doesn't appear to be the same fan/kit.
pjtoledo
2,991
Toledo Ohio
Fords
3.0 2.3
on my 2005 the wires going to that fan are not heavy gage.
Linus72
7
Orange, va
Mazda B3000
Ok thanks for y'all's help!
I do have a 2007 Taurus that I'm gonna junk after I cut out the 3 cats lol.
It has a efan setup, could I install this in my truck or what?
Thanks
stmitch
MTOTM Winner
650
Central Indiana
I don't know that I'd trust the efan alone to cool a truck towing close to it's max, up a serious grade but It's been cooling my supercharged 3.0 street truck just fine for a decade. If you're not comfortable with a new Dorman version, then you can go to a junkyard and grab an actual Ford one that's 10-20 years old now. There's risk either way I guess.
I'd put the Dorman or OEM Ford e-fan up against an aftermarket fan with no shroud any day personally.
Uncle Gump
Token Old Guy
13,532
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Well I didn't say it wouldn't work... but if it's that good it just makes me wonder why Ford didn't run it stand alone and chose to run a mechanical fan with it. I would think they extensively tested and would have eliminated the clutch fan and saved $10 or $20 per vehicle at a time when they were cost cutting even down to a couple pennies a vehicle. I mean... they had been running efans for decades on other applications. Would be nice to actually see the specs for that fan... but I still guess it isn't big enough.
No argument on the importance of a shroud from me. Shrouds are far more critical with larger gaps between the radiator core and fan blades. Most of these aftermarket e fans shroud themselves and allow very little air to be drawn from around the fan itself.
Blmpkn
Toilet enthusiast
6,374
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Back when I had my 2010 I *think* I read a few folks proclaiming that just the supplemental e-fan was enough to keep a 4cyl cool.. but.. those motors seem super over cooled from the factory anyways. That truck was the only vehicle I've driven where sitting at a 1 minute red-light in January would cause the temp guage to drop by a third.
May not be enough fan for a 3.0.
