Electric Fan Install
Harris
Blakely, Georgia
2.3L
I know there is an article in the tech section already, but I kinda just wanted some feedback on what you guys think about my install. I highly value your opinions on Ranger issues.
I was at the junkyard Monday getting in some much-needed shopping when I figured an electric fan would maybe help add a little horsepower to my '94 Ranger. The little 2.3L needs all the help it can get, plus a little added fuel efficiency wouldn't hurt either. Anyway, I measured my radiator and struck out looking for something close.
I found a 2002 Pontiac Montana with a fan that looked pretty close to what I needed so I pulled it. I checked to see if it worked and gave the junkyard owner $8.00 for it. If you do decide to get one like I did, make sure you remember to get the snap-together coupler with the wires, too.
http://s268.photobucket.com/albums/jj33/harris3810/?action=view&current=SlightlyUsedElectricFan.jpg
I pulled the old fan/clutch assembly out, along with that aggravating fan shroud.
http://s268.photobucket.com/albums/jj33/harris3810/?action=view&current=OldBelt-DrivenFan.jpg
To my amazement, when I lowered the fan into place behind the radiator it was a near perfect fit. After cleaning the fan and its housing with Bleach-White and a brush I gave it a good shot of Turtle Wax Ice to make it look a little better.
I used longer-than-original bolts to hold the top and bottom in and a 1/2 inch PVC coupling sawed in half and painted red to conceal the gap from where the fan didn't mount exactly flush.
I also painted the metal cover over the fan motor red. Go Dawgs!
Now that the easy part was over it was time to wire it up. There was a good grounding spot right next to the top of the radiator on the driver's side, so I used that. I ran a good 10 gauge wire around the battery and to the power distribution box. A relay from an F-150 came in handy and everything tucked nicely into the box. Since I did not have a thermostat switch I simply wired it up to run when the key is on. To remedy any future problems I put a small unobtrusive switch in the cab so I can turn the fan off if I need to. The wires going to the switch can easily be re-routed through a temperature switch when I get one, but so far it's working fine.
Fan: $8.00
Misc. Electrical Stuff: $3.00
(Most of this I had laying around. If you went out specifically to buy the electrical items you could expect to pay around $10-14.00.)
Paint: $4.44
PVC Coupling: $.21
Time: About 2 hours. Next time I could do it in one.
http://s268.photobucket.com/albums/jj33/harris3810/?action=view&current=ElectricFanCleanedandInstalled2.jpg
Maybe someone can learn something from this post or someone can offer me some advice on how to do it better next time.
gotmudd
PORT ANGELES, WA
FORD
390C.I
i learned from experience that you will need to put in themostatic fan relay otherwise engine will run too cold and you will build excess carbon. you can get relay at shucks auto supply @35.00 dollars, takes @ 15min to install
Harris
Blakely, Georgia
2.3L
That's interesting that you bring that up. I have noticed that my original fan ran all the time and the needle on the gauge never got above the N in Normal. With this electric fan it now sits on the O in Normal. I do intend to put a temperature switch in, though. (I am a college student, so it may take a week or two to get the switch.)
gotmudd
PORT ANGELES, WA
FORD
390C.I
did a conversion on a '78 camaro, before putting in switch it ran like a pig cuz the thermostat wouldn't get to temp, put in switch and it runs like a champ, 22mpg highway, not bad for a 350chevy w/edelbrock 4bbl
Harris
Blakely, Georgia
2.3L
Sorry to bring this thread back to the top but I wanted to report on how my 2.3L is doing after three weeks with the electric fan. Before the fan, (and no other changes) it was getting about 19.8 mpg consistently. (I know that's kinda low, but I'm working on it...) My first refill after all in-town driving came out to 20.8 mpg and I refueled yesterday after 280 highway miles and it was at 21.9 mpg.
So far I will claim that just the fan has given a 1.5 mpg or 7.6% increase in efficiency. I am not saying this is the best setup, but so far I am content with the improvement.
Now I just need a new cat and I'll see what that does. If I can get to 24-25 mpg I'll be pretty satisfied.
Bob Ayers
16
Durham, NC
Your engine running hotter is the reason for your increase in MPG!
Harris
Blakely, Georgia
2.3L
Maybe that's all it is. I am still satisfied with the change.
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
dude you are stupid.....engines DO NOT run hotter w/ efans.....it has been proven time and time again.....
milage increases is because there is less drag on an engine.....a hotter engine will get worse fuel milage....
STOP GIVING FALSE INFORMATION Bob.....did your parents have any kids who had common sense?
Harris
Blakely, Georgia
2.3L
Well, mjones, when I first installed the fan the temp gauge went from below the N in NORMAL to almost the O, but since then I have blown the radiator out with an air hose and flushed the system, so for the last 2 1/2 weeks the needle has stayed where it always was. Also, I have heard that a warmer engine is more efficient regarding fuel usage but a cooler one will have a longer life. I don't know, it's just what I have always heard. I do feel that for my application purposes thus far the electric fan has been a positive addition. If my alternator fails and I am stuck in a parking lot next week I may change my mind...
I will ask, however, that you please not call someone stupid or false on the thread I started. I simply wanted to gather information and hopefully help someone else who may be looking into this modification. If you do disagree on with a post there are more adult ways to express the dissenting opinion you may have without being quite as coarse.
mjonesjr
Firefighter
13
Salem, IN
sounds like you had something blocking the radiator is the reason that it read different....
it takes course words to get through to Bob....he isn't all there....
Bob Ayers
16
Durham, NC
You need to re-read the OP's posts....because he does say his temp gauge is running hotter with the e-fan. WRONG about a hotter engine, the way modern EFI works, it will lean the mixture the hotter the engine gets!
And, for F.Y.I. an e-fan has less cooling capacity than a mechanical fan/clutch
Bob Ayers
16
Durham, NC
You are correct Harris! You will get better MPG with a hotter engine, and there will also be less wear.
gotmudd
PORT ANGELES, WA
FORD
390C.I
engines are designed to run within certain heat ranges, therefore if you run above the recommendations you will burn up your rings [been there] if you run below the recommendations you will build carbon and eventually lose power. THAT is why electric fans have thermostatic switches, to keep your engine at the temp. it was designed to run at. as mjones said less drag=better economy:D
Harris
Blakely, Georgia
2.3L
I think the issue has been exhausted on this thread. I will perhaps update it during the summer months where the electric fan will get it's true test in the south Georgia heat. You can expect an honest evaluation of the electric fan as I would not purposefully mislead any TRS readers. I will say that, as of three weeks in, I am satisfied with the fan and it is performing better than I hoped. It was just a little project that could occupy me on my day off.
To gotmudd: As far as the temp gauge goes, the fan did let it get a little hotter than the original, but only between the N and O in NORMAL. I remember ten years ago thinking, "Does the temp gauge even work on this truck?" I put a piece of cardboard over the radiator and drove around for a few miles before it even moved, so it has always stayed quite cool. In January I Sea-Foamed the hell out of it but some parts, like the EGR valve, were clean as a whistle. I guess it's one of those, "If it ain't broke," kind of situations.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,747
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Knock it off. There's no reason for name calling.
No members online now.
