- Nov 13, 2018
- 4,482
- Canaan,NH
- Ford Ranger
- Engine Type
- V8
- Engine Size
- 351
- 2WD / 4WD
- 2WD
- Total Drop
- 3"
- Tire Size
- 235/55R16
- My credo
- If you don't have time to do it right will you have time to do it over?
This isn't about my Ranger, I'm working on a 57 T Bird with a stout 351 with aftermarket port injection with EEC IV. The Id on the processor is from an 89 Crown but I'm sure the internals are non Ford, there's a square hole cut in the side of the case and a programmer plugged into it. A phone cord plugs into the programmer and connects to a 1 1/2"x2"x3/4" box with a 5 position switch. Last year I found it would run best with the switch in the full counterclockwise position and ran lousy in the middle 3 spots. This year it runs lousy in the middle 3- with the check engine light on- and dies on either end position. I suspect they jump started it backwards this spring because I stopped him from hooking up the cables backwards when I tried to get it running. Neither the programmer or switch box has any identification. The programmer box says Hammond 1551K on the inside, that identifies the empty plastic box. Anyone know of a company that can fix or supply a programmable EEC IV processor? The other choice is rewire the whole mess for the OBD II system they now use. It's a Mass Flo efi system, the man who owned the car died, as did the man who started the build.
