Easiest way to modify my open diff to a limited slip.
Great_Big_Abyss
Winnipeg, Manitoba
My 2006 Ranger has axle code 97: 8.8, 4.10, 28-spline.
What is the easiest (read: cheapest) way to turn this into a limited slip diff?
Is it possible to swap the carrier from an FX4 into the open diff of my truck?
What about the carrier from the FX4 level II? What is the difference between the limited slip diff from the FX4 level II and the plain old FX4?
Great_Big_Abyss
Winnipeg, Manitoba
Hmmm, so it seems like at FX4 axles are 31-spline, so I do not think the FX4 carriers will fit in my 28-spline.
I wonder, what are good aftermarket limited slip carriers available to a 8.8/4.10/28-spline rear end?
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
Just swap in an entire axle that has limited slip.
Sent from my XT907 using Tapatalk 2
ford4thot
Lunchbox locker?
kunar
131
Toledo, Ohio
5.8l
i entirely agree, one of the above. swapping in an axle is kinda a big job, but its all fairly basic work. putting in a lunchbox locker is fairly straight forward, but its a locker, not a l/s. as for swapping in a different carrier? that's gonna require setting up gears. not something the average shade tree mechanic wants to tackle.
Schnot
Ringtown, PA
2.9L
I agree. This will be the easiest and potentially cheapest depending on where and when you find an axle.
Sent from my iPhone.
Great_Big_Abyss
Winnipeg, Manitoba
Axle swap is what I may have to do. I don't want to put in a lunchbox, as this is a daily driver and is only a '10% off-roader'.
jrpdash9
eau claire pa
I have a axle. If your located close. Where you at?
3,614
Wenier-peg isn't exactly close to Eau Claire.
3,614
Adsm, its Winterpeg.
And your right. Winterpeg isn't exactly close to anything. lol
Someone on here has it down as "weinerpeg" in their profile.
mooner67
Michigan
I'd find an explorer axle with LS. swap out all the guts and axle shafts and you'll have a 31 spline axle without having to unhook yours. Also if the explorer axle doesnt have 4.10's you can just swap your ring gear and pinion in place of the explorers.
PlumCrazy
179
Millersport, OH
Solid Axle Swap 4x4
Doesnt work that way...31 spline stuff wont fit in a 28 spline housing. The widths are different as are the bearings.
mooner67
Michigan
Hmm.. I never realized that
No members online now.
