Duraspark Problems
Abernathy311
2.8/2.9
I am doing a Duraspark conversion in my 1985 Ford Ranger. I Have connected everything and my engine wont't even crank. I connected it using the 84 method on the tech article, because my truck has the transmission from a 84 and its emission standards are for a 84 according to the sticker above the radiator.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Normally if it started and ran before you did the swap then it's most likely something you did or didn't do. Not trying to sound mean, but you have to go back thru and check everything you did. Could just be a bad connection somewhere. Did you do the trouble shooting tips in the tech section too? Did you have the harness for the swap or make one? New Dizzy? I did mine from the tech page and it fired right up and ran well. So just go thru it again and double check and let us know.
Abernathy311
2.8/2.9
I got the loom and parts from a 84 ranger with the conversion. Both ran before the conversion.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
So is it even clicking on the starter? Or nothing when you turn the key? Try to describe it more. Nothing means it's not getting power to the starter. Battery good? Gotta be in the wiring. Solenoid good?
Abernathy311
2.8/2.9
I hear nothing when I turn the key. I jumped the solenoid, but it didn't engage the starter. The solenoid fired though.
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
Really sounds like a wiring issue to me. Grounds all good on the Starter? Pull it and bench test it if the grounds are tight. When it quits raining here I'll take some pics for you of the wiring. But it should've been all plug and play mostly. You made sure you only removed unneeded wires right? Post some pics of what you did if you can.
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
Did you follow the wiring diagram and instructions for your 85. They have different wiring than an 84.
Sent from my SM-N910P using Tapatalk
Abernathy311
2.8/2.9
I removed the unnecessary wires. I don't have the wires and/or plugs that the tech article describes for the 85 conversion. So everything is rigged up for the 84 conversion.
Abernathy311
2.8/2.9
Would there be a possibility that the red/light green wire would be a different color. I have traced the wires using the TFI module, the coil, and computer. All the other wires seem to be in the right places. There is a yellow with blue marks wire that goes to all of the same places as the red/light green goes in the diagrams.
