frankp05
- Nov 4, 2015
- 0
- Ford
Kim this is getting ridiculous!! Haha my TFI coil is wired up correct with the Positive side of the coil running to hot when on and the Negative side is wired to the green on the module but even with the key just turned to the on position just sitting there Without Cranking the motor, my coil wether it be the TFI or Canister just get really hot and there is no spark on crank. So I got a ballast resistor wired up and it the resistor gets really hot keeps the coil from getting hot like it should. Going back to the spark issue it seems to work better with the resistor wired in line but its not very consistant. I havent tried making it start and run because I know im just gonna beat my head because it wont start. Ive wired it up two different ways first exactly like the TRS Tech Article expalins then like this https://www.google.com/search?q=duraspark+2&biw=1600&bih=799&source=lnms&tbm=isch&sa=X&ved=0CAcQ_AUoAmoVChMI-NTwsfH6yAIVQhk-Ch04Mgcm#imgrc=DAlszNN0OJCKIM: ....
It seems to spark better with the resistor and it keeps the coil from getting hot. I just want to make sure im not gonna fry the Ign. Box or coil.
