Driveshaft help
MIKRIB
houston tx
2.9
im in the middle of putting a 99explorer 8.8 w/dic brakes in my 88 b2
i would like to keep my drive shaft since i just had it custom made about 2 years ago to replace the cv one i had in there is there an adapter flange i can buy so i can bolt it to the 8.8
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
Is it a 1310 u-joint shaft? If so, all you need to replace is the rear flange on the driveshaft itself with one from a Ranger or early Explorer, then it'll bolt up no problem.
MIKRIB
houston tx
2.9
i do have the 1310 u joint do you know a place were i can buy the flange
website or parts store not having any luck locating one
Driveline shop.
Junk Collector
Truck of Month
4,807
Rapid City SD
PM me, I am pretty sure I have at least four or five laying around.
Junk Collector
Truck of Month
4,807
Rapid City SD
Never mind, I do have 1310 flanges but they are the small (earlier) bolt pattern for the 7.5. I also have 1210 flanges for the small pattern too... but nothing for the larger ones. Dangit. Now I remember why I had to buy one :sad:
You can always clamp your flange onto the pinion and drill holes... the inner circle part that is machined out is the same size, then just use bolts with nuts on the other side of the pinion flange, or tap threads into it. That's what I did back in the day.
This is what worked great for me:
spdcrazy
Homer, alaska
mostly 86
B2
2.9 bored and cammed
i think napa can get them too. not the easiest thing to find, so get a napa guy that knows what he is doing... def not gonna be in the computer..
MIKRIB
houston tx
2.9
thanks... ill try the driveline shop if that dont work looks like im drilling holes
No members online now.
