drive shaft rear bronco II ?
lchappyjr
Kalama, WA
I have swapped 92 explorer motor,transmission, transfercase, dana 35, and 8.8, also skyjacker 6" lift, I want to put a double cardan joint drice shaft in rear form explorer front shaft. Is this possible and what do I need? I have the explorer rear shaft. Its mostly a daily driver so I dont want vibration.
TexCaliBII
4
Palmdale, California
Hello,
Yes there is. You need the forward section of the rear shaft, the cardon section of the front shaft and you have to cut out the double cardon section to make it into a standard looking yoke. You then take the axle end yolk off the rear shaft and put in on the modded part of the front shaft. I did this for my 87 that I put an 8.8 in but had stock BII gear otherwise with a 6" lift. It did not work well as I got vibes/grinding from it no matter how I massaged it. For a daily driver I recommend a custom made shaft that is not a cardon type. I am in the process now of modding a BII rear shaft to mate to the 8.8 I put in my 88, well really it's a 93 Explorer.... I was looking for the link I used for this info but can't do a search for from work. :annoyed: I'm almost sure it was on http://www.explorerforum.com though. Hopefully you’ll have better luck than I did. If it had not been a daily driver I might not have minded so much but it was, and did. I pulled the lift back out and put in an aftermarket straight shaft I found in the JY on a 90 BII. Good luck.
