Don't cut your heater box!
whisperer
Bend OR / Hilo HI
Ford & Mazda
2.3, 2.9, 4.0, 2WD SBF swap.
The plastic that the heater box is made from is some kind of styrene and responds well to heat. All I did to make clearance for the valve cover was to mark the area that needed to clear, heat it up with my heat gun and push it back. It took literally 3 minutes.
The box is fairly thin material and I think a good blowdryer would have done it if necessary. I used an oil filter as the item of choice as the "push-former" and it made a nicely rounded dent that is perfectly sized to clear even my tall race valve cover on my 302. It would also have no problem clearing with a 351W with normal covers.
Grey_04
50
pennsylvania
whisperer, sounds like a cool deal . I'd be interested in seeing an after pic..
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
Cool!
...and remember, not necessary for '95 and later!
whisperer
Bend OR / Hilo HI
Ford & Mazda
If you want pics I'll snap a couple tomorrow and post them up.
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Great tip, thanks.
Richard
Grey_04
50
pennsylvania
dam that was a clean job, whisperer.
JoeyB
Everywhere but right now Asheville, NC
302 / TF heads & cam, Harland Sharp rockers, Intake, Holley Carb, MSD, 5 speed with Hurst Shifter
I just spent a bunch of time with flashing modifying mine this weekend and it doesn't look all that good. I wish you would have posted this on Friday... Sweet tip:icon_thumby:
Iron Ranger
Run lil' ricer RUN!!
MTOTM Winner
22
Minnesota
0.040 punched 302
Are you kidding me!!? :icon_surprised:
OK, this one DEFINITELY has to go into the tech library! :icon_bounceblue:
Do you have any idea how long I took fabbing a sheetmetal cover for mine!!? :annoyed:
SCOTTYFIREMAN
How about if you want to leave the A/C?
Has anyone did that as you know of?
r1hatman
4
Knoxville, TN
2.8
t_dickie
Brandon, MB
331
Nice job! Did you do that to a 2wd or 4wd? Would it work for a stock height, no A/C 2wd swap?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
500 watt light works too....take it off and lay it flat, light on corner till its soft. you can shape a coffee can under it and it will lay in pretty good
done this many different ways over the years, fire is bad for it. in the early 90's the guys at total performance did it with heat and big metel spoon thing dipped in oil. my current box was heat gun but i was impatient and need to do another..but i may just leave it. they do bust easier after you do it deep.
351 swaps with ac i find it easier to cut and make a metal piece with a tube to the blower feed hole
did not realize this type of info was not around anymore....
Duane867
9
Columbus
2.3L
Why the HELL didn't I think of that when I did mine ?
