Dome/Map light issues (solved)
Cooper_G
Hows it going. I have a 98 ranger xl and am having some dome light issues. The light comes on and off normally with the driver door but when i open and close the passenger door the light stays on for about 1-2 minutes before a relay audibly clicks somewhere in the dash. If the truck sits for around an hour or so the dome light doesnt turn on with the doors or dimmer switch and the dome light assembly reads 0 volts, however if I start the truck it works again. Battery voltage after sitting for an hour and light no longer working is a perfect 12.38 volts and with truck off and light on it is 12.28 volts. I have also tried the wd40 trick on the door hinges but no luck. Any help would be much appreciated.
Sent from my Z982 using Tapatalk
