doing clutch on 91...need torque specs
funkingonutz
Enfield CT/LongmeadowMA/AgawamMA
3.slow
So im doing a friends clutch for him today and i went to look for my haynes manual for all the torque specs and i cant find my damn manual. Can someone look them up for me please, i think i need the flywheel to crank specs and the pressure plate torque specs. Thats all i think i need..but not sure.
its a 2.3L by the way....
He bought the clutch kit (clutch disc, pressure plate, and throw out bearing, pilot bearing) and a new flywheel.
Please hurry :D:D
Need the driveshaft torque specs too...i think
bobaloo
Casco, Michigan
4 Banger
Torque Specs
These are the torque specs for a 1994... should be the same:
Clutch Housing to Engine Block Bolt 28-38 ft.lb
Clutch Housing to Transmission Nut 30-40 ft.lb
Pressure Plate to Flywheel Bolt 15-24 ft.lb
Insulator to Crossmember 71-94 ft.lb
Insulator to Transmission 60-80 ft.lb
Starter to Clutch Housing 15-20 ft.lb
I couldn't find the driveshaft torque spec.
Hope it helps
94 lngbd
7
Lakewood,Wa
2.3l
im doing the same & still need the torque specs for the flywheel bolts. That spec wasnt given.
scotts90ranger
4,413
Dayton Oregon
2.3 Turbo
I think it's like 75lb, but the last two times I put the clutch in mine I didn't torque them down, just put some blue loctite on the bolts and tightened them down.
captanron
Flywheel to Crankshaft
91 ford Ranger 2.3, F17A-KB M5R1 5sp transmission. (Nondetachable bellhousing). Apply locktight to bolts and torque to 56 - 64 ft-lbs.
