- Feb 21, 2014
- 2
- CenTex
- Ford
- Engine Size
- 2.3
Mostly I'm talking about fuel & clutch hydraulic lines, but I'm totally open for conversation about any of this. In another post I mentioned that I've had to drop my fuel tank because a crumby little plastic piece that broke off the top of the fuel pump. I bought the cheapest fuel pump I could find online ($75) thinking that the pump itself is actually good so I could use the housing from the new one and simply replace the pump unit when (not "if") the pump goes out - assuming the fittings on the cheap-o housing hold up. I simply didn't want to fork over a couple/few hundred bucks for a lifetime warranty part when I keep hearing an old mentor's voice in my head saying, "A cheap part w/ a lifetime warranty is just guaranteed to need warrantying for life." In other words, it may be free to change it out forever, but you'll forever be changing it out.
I was explaining the problem with my truck to my buddy online, and the fist random pic of a fuel pump just happened to be an APS assembly for a GM.
I was explaining that about where this guys fingers are in the pic. is where my fuel pump broke because mine's made out of plastic, and I thought to myself then that this guy will NEVER have the problem I've got, and I want one like that - totally worth a couple/few hundred dollars to me with or without a warranty because I'd know it can be rebuilt indefinitely.
While I was under my truck dropping the tank, I also noticed that I have a fluid leak somewhere between the engine and trans, but I cringed and backed away without inspection knowing that it's either the rear main seal or a leaky slave cylinder, either way it spells "dropping-the-trans" and I was in no mood to entertain the idea. I'll have to poke around in there when the new fuel pump arrives.
It's come to the forefront of my mind about every time I have to skip second or I grind into first that a Tremec upgrade would be a good thing, and some attention will soon become absolutely necessary in the trans department. I've been mulling over these sorts of things wondering about the best way to toughen my truck up so that these essential but flimsy/brittle plastic bits are not quite as vulnerable. At first I was researching how to throw in a T-5/S-10 hybrid trans with a turned input shaft & a Q4R bell-housing ($!) since T-5's are fairly common and renowned as reliable. I know it's not technically a "truck" transmission, but that can be argued about the Mazda trans too
I've been weighing the pros and cons of rebuilding stock and/or a custom upgrade in pursuit of making this truck last forever. The off-the-shelf clutch master cylinder that will operate a TR-3650 slave cylinder from an '04 Ranger still evades me, but I'm not quite there yet. My goal is two-fold: ~300HP, and make it a driver until it's VERY old. A big issue to me is trying to get rid of all the crumby snap-connections and replace it with some nice SS-braided stuff, though I have yet to find anything for the M5. Sorry for making this post into a book. Any thoughts or ideas, cool links?
