DIY Wheel Balancing
jpark6491
Illinois
2.5 L4
I was just curious if anyone on here balances their own wheels themselves using a portable wheel balancer, similar to what you could buy at Harbor Freight. I am planning to get some new steel wheels soon and was considering doing it myself.
I realize that having it done with dynamic balancing would be most ideal, but just wondering if others have had good success doing it yourself.
fastpakr
2,845
Roanoke, VA
I tried it on the 285/75-16's on my '99 with the HF balancer. Got them close enough to be driveable, but it shook quite a bit on the highway. Ultimately I gave in and paid a local shop to do a proper job with a spin balancer, with much better results.
I'll continue to use it when I mount my own tires, but with the willingness to let somebody else take over the job depending on how the test drive goes afterward.
17,971
SW Iowa
Bubble balancer and a bucket of old weights works for me.
racsan
4,499
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
At one time I was going to buy my own mounting and balancing machines. Then found out how much they cost. Wow... yeah, I’ll pay to have that done.
alwaysFlOoReD
5,135
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I bought a used Coates 5060a and a Snap on balancer for $C500.00. Right now there is a balancer on kijiji for $150, but the motor is 3-phase.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I tried the HF bubble balancer myself, with much-less-than-stellar results.
I ended up building my own spin balancer since I figured (correctly) I'll likely use it again & again in the future. I detailed it here in the Homemade Tools post. It tends to use up slightly more wheel weights due to the two-step method involved (static, then spin balancing), but the final results I've gotten have been on par with what you'd typically get at a tire shop.
91stranger
512
Gets Mo Chicks
its like $20 a tire to get it done around here. Is that more than buying a balancer, assembling said balancer, attempting to balance wheels yourself, put wheels on, take for a drive and find out they shake worse than before? That's my luck. I'd rather pay someone else to do it. I used to balance tires everyday for 2 years and I wouldn't trust myself with a harbor freight cheepie. When you stop and think about $80 for guaranteed balanced tires (if they aren't perfect most shops will do a free re-balance within 30 days) is a good deal.
jpark6491
Illinois
2.5 L4
It was just a thought...was mostly interested whether anyone had attempted themselves or not.
I probably will be taking tires to the shop in the future.
pjtoledo
2,998
Toledo Ohio
Fords
3.0 2.3
have a cheap bubble balancer, Ranger brand. not the best results. repeatability is poor, bubble is too small to see tiny offsets.
sgtsandman
Aircraft Fuel Tank Diver
12,774
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
From my understanding, home balancing is better for vehicles that stick to low speeds. Your results may vary for on road use. There was a time when bubble balancers were the norm in tire shops. So it can be done and made to work.
Bird76Mojo
1,265
IL
My father hasn't had a single tire balanced for over 40 years. He also hasn't bought a single new tire in over 30 years easily. He has excellent luck I guess.. None of his vehicles have ever vibrated on the road.
17,971
SW Iowa
I don't even think dad paid $20 for his. He got it used, a old small shop sale after the owner died.
Junk Collector
Truck of Month
4,858
Rapid City SD
It's $40-50 to have a set of four balanced around here... usually I just have a shop do it. I wouldn't mind finding a bubble balancer but I'm kinda running out of room in my shop to store things like that.
I do virtually all of my own mounting though. A handyman jack will break the beads and I have a set of tire spoons.
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I just bring them into work and have one of the guys mount and balance them.
North Idaho 5.oh
554
Idaho
Ford ranger
I work at a local tire shop and do my own balancing and have zero issue. ??
