disciplerocks's Ford Focus "build" thread
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
I'm friends with him on Facebook.
NEALD
Oh god.. Good stuff or bad stuff??
Robert_1967
13
White Pine, TN
302/2.9
it has a 5.0, any and all stuff is good.
Unless he puts the 4cyl back in it, that would be bad.
Robert
posted using a cartoon, and a ps3 controller.
dangerranger83
54
Lafayette, IN
It's killing me not to say...
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Dustin has put a lot of work into it. I don't think a single one of us hasn't had the "how in the hell did I forget to do that" moments. Project complete, it's going to be a pretty bad arse one of a kind car. It's not every day you see COP on a SBF, let alone in a Focus.
Sent from my A210 using Tapatalk
Yeah, I was really confused when I saw the COP until I scrolled down and saw the diagram.
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
Because race car
While I'm working on the motor, I am going to be installing a temp gauge, oil pressure gauge, wiring in the crank sensor to the Focus ECU in hopes that it will make the tach work, wiring in the VSS, reinstalling my wideband, and I am swapping to stainless hardware.
I also welded shut the coolant lines I was not using, which was the one that blew off.
Found out the Focus crank sensor is a 36-1 tooth just like the Explorer so I'm good there.
But I need some input on the VSS. The Ex ecu uses a 2 wire sensor like most RWD Fords. One is ground, the other is signal.
The Focus uses a 3 wire sensor. One is ground, one is switched power, and one is signal.
Got it running again.
http://youtu.be/Hsv0lg7u8Dk
Then tore it back apart to work on oil leak around lower intake.
New sticker
Making a new COP harness
Another video
http://youtu.be/L_qpZGqVLds
dangerranger83
54
Lafayette, IN
He's getting closer to having it "done"
I thought that you were going to be supercharging it though.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
It'll never be "done". He's probably waiting for me to build the adapter for him, since I'm currently fabbing one for the supercharged 5.0 jeep I'm building...
SVT
disciplerocks
53
Evansville, IN
Are you fabbing another one? What about the old one?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Yep, took the first one, modified it to make the new one. I do have an M90 plate cut out of 1/2" aluminum though, so I've got the start of one...
SVT
disciplerocks
53
Evansville, IN
Mine is going to have to be a remote mount. I don't have the clearance in the back.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Youll be surprised what majic I can do. You of all people should know that :icon_thumby:
SVT
SVT
Can you pull a small block out of your ass?
That would be a cool magic trick.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
If I pull on a stick...lol
SVT
