Did I get the right transmission fluid?
bluebombersfan
I have a 2006 3.0 5spd. I went to piston ring and asked for transmision fluid and he gave me Mobil atf d/m fta d/m. just wanted to make sure this is correct before i put it in
8,372
Yes, Ford M5OD manual transmissions use ATF(automatic transmission fluid)
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Does it say on the bottle something to the effect of: "For applications that require Dexron III / Mercon automatic trans fluid", along with: "Not for use in applications that require Mercon V fluid"?
If so, then you have the correct stuff. :icon_thumby:
jeremysdad
ASE Certified Tech
May be wrong, but don't the newer models spec Mercon V for the trans?
Newer everything specs Merc V because the original stuff was discontinued and V is supposed to be backwards compatible, but many people report shifting issues when using V.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
2008 & later specifies Mercon-V for the M5OD.
Edit:
Looking back at the OP, he simply stated "5spd"... Perhaps we should make sure he indeed meant the stickshift, and not the 5-speed automatic...
The auto actually does spec Merc V as far back as 1997 I think.
