- Aug 7, 2007
- 12
- Troll land
- BIITR
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- 2WD / 4WD
- Solid Axle Swap 4x4
- Tire Size
- 42
Ok so I found a deal on a HP Dana 60 and 10.25 FF, so its time to say bye bye to TTB for this TTB believer.
I am going to go leafs in the front, keeping the axles full width and out boarding the springs as I believe that’s the only way to spring it full width as it’s a leaf 60. lifting minimal amount of lift to clear 40’s with more fender trimming. The engine cross member is going to be substantially reworked in order to keep it out of the way of the diff at full compression. I.E. clearanced and reinforced. Cross member up front built off the existing winch mount/bumper frame mounting plates with shackles in the rear or front? Might move the front axle forward as well. Also im not worried about street manners, this is and will continue to be a trail toy only. The only high speeds this thing sees on the road is on a trailer.
My question is about springs. What long leafs can I use to net me good flex and not a ton of lift with both the lift and flex being well tunable with the addition or subtraction of leafs form the pack? Also shackles in the front or rear?
I was thinking about rear explorer leafs as that’s what I am running in the rear and plan to keep running in the rear with the 10.25 for the fact of there flex. But are they to long for a front application? And I don’t think they will be able to give me the lift I want in the front. I don’t want it in the clouds but I still want to fit 40’s.
In my searching I read about chevy 52” springs for front SAS. I am leaning towards these spring. Anyone have any input on these or any other spring that might suit me well for the above criteria I have mentioned let me know.
Also here are a few pics of my truck so you know what I am starting out with and visualize what Im trying to do. Not sure on lift, maybe 6” net. Fenders trimmed sitting on 37” rubber. Looking to get flex from the front 60 close to what I have in the front with the TTB.
