Tognot
- Oct 25, 2021
- 1
- Desert of ca
- Ranger
installing a lock right in my Dana 35 ( I hope). Got the unit out of the truck and on the bench, and after starring at it for an hour and searching for about 3 hours….. I can’t get the carrier assembly out of the housing . The ring gear ( OEM 4:10) is too fat to let the center pin slide out. I unbolted the ring gear in hope I could slide it over, but nope, it hits the pinion gear.
the hang up is the clip on the stub axle , I can’t get he clip out unless I remove the center pin. I can’t remove the center pin due to the fat ring gear. I know there must be an answer that will embarrass me for not thinking of it , but I’m ok with that
thanks for ideas !!
