Dana 35 build
4.0B2
151
Walls, MS
4.0 v6
So since I've almost got everything for my 8.8, it's tile to stock pile parts for the d35. It's stock as of now, except some SOB stole my manual hubs. It had some warn hubs. Will I have to buy warns to replace them? They only took the outer metal part... And what else will I need for the swap in my b2. I know I need new drop brackets. Still trying to locate some cheap ones or get money together for a set on here. Also I'll be using jeep coils from a XJ hopefully. And probably an Aussie. What else, or once again do I have everything covered? What about trusses? Or is the housing plenty strong.
And I know there is an axle tech section now so if someone needs to move it they can...
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
i have a set of warn hubs off of a 1st gen explorer i would let go for $50 shipped.
4.0B2
151
Walls, MS
4.0 v6
Warn manual hubs? I'll take em! Pm the paypal info. What comes with them?
The_Dealer
10
Macon, GA
Duh!
i thought all the drop brackets were the same??(btween d28-35)
4.0B2
151
Walls, MS
4.0 v6
You can't use the rough country drop plate. So the plate has to be replaced with an actual beacket.
The_Dealer
10
Macon, GA
Duh!
ill swap u for my 2.6" tuff country drops
4.0B2
151
Walls, MS
4.0 v6
I don't think that's gonna drop? I plan on using a +3-4 xj coil
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
i think you can use a drop plate, but you run the risk of punching a hole in the D35 pig.
sasquatch_ryda just posted a thread showing where he bent the driver's side beam of his D35, so no, they arent plenty strong if you plan to wheel them hard.
AllanD sells manual hubs for D35's for $90 shipped
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I trussed the front of my drivers side D35 beam after I bent the stock one in the middle.
4.0B2
151
Walls, MS
4.0 v6
Which ones do allend sell? I have the offer on the warns which are fine in my opinion.
And I doubt id ever bend the housing but I'm building now for the future... So why not?! Lol
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
The ones I sell are all whatever I find on junkyard Rangers and/or Explorers.
AD
4.0B2
151
Walls, MS
4.0 v6
Ahh okay. I'm Gonna talk to baddis about the ones he has.
4.0B2
151
Walls, MS
4.0 v6
so.. instead of making a new thread,
seriouslly... best steering option are?
superrunner, modified slightly-- or stonecrusher set-up? i'm getting money together for one of them...
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Stone crusher.
