- Jan 23, 2011
- Reaction score
- 983
- Location
- Bronson Michigan
- Make / Model
- Ford Bronco II
- Engine Type
- 2.8 V6
- Engine Size
- 2.8
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- 6” skyjacker 2” body
- Tire Size
- 33x12.5
I swapped the Dane 28 for the 35 in my 85 BII. It has a skyjacker 6”suspension lift. Was in build process so haven't driven it till now. Been testing all the new components and have run into an issue. Left axle beam pivot bolt is contacting right side axle shaft. Right side axle shaft is close but not touching the right side axle beam. I can cut the bolt to make clearance but I’m unsure if something is off. Any of y’all with a 35 in your rig have the same clearance.
