CopyKat
- Aug 18, 2007
- 8
- Manitoba, Coldest place in Canada
- Ford
- Engine Size
- 4.0L
That was long ago Jim.I mentioned this to Joel a couple of years ago and have been sitting on the idea.
I wanted to do this to TRS-2 later this year and add the 44 knuckle swap.
Since you guys are doing this, I'll go ahead and tell you my ideas......
I had two ideas on how to do this:
1 - Make a thick ring (like say 3/4 or 1-inch) that has two sets of holes in it. One set that would allow bolts to recess in to the ring and hold the ring and diff housing to the beam sandwiching the beam between them. The second set of holes would be tapped to allow a cover to bolt to the ring.
2- I like this idea better, a thick ring like above, but it would be welded to the beam to strengthen the beam from the section being cut out. Again, two sets of holes, but the holes for the diff housing would go through so that the original bolts would be bolting the diff housing to the beam, but be recessed in to the ring. Again, a second set of holes would be tapped to allow the cover to bolt on.
I don't like the idea of a cover that uses the same bolts to hold the diff housing to the beam.
I think the ring should add some strength back in to the beam since your cutting a section out.
Sharpertouch, I think you should take the design a step further. I wouldn't want to worry about the diff housing coming loose when I take the cover off. I would want to be able to take the cover off and clean all the crap out without worrying about the sealant holding the diff housing to the beam.
I tried the whole pump idea to get the diff fluid out from the fill hole. This idea sucks. It took forever and is a pain in the ass. I doubt I even got all the fluid out. Have you ever looked at the slime that get's in your diff from playing in muddy water? Yes, I have vent hoses but it still gets in some how.
Ya the thought has crossed my mind from time to time. I was thinking of doing it with the new beams I built but after seeing how easy it is to bend them in stock form. I voted against the idea. If I was to do it for a street truck i would go the #2 route Jim mentioned.
For simplicity I did the same as sasquatch and drilled/tapped a hole for a plug on the bottom of the housing. I don't have an e-clip, because I have a lock rite, so it's a moot issue for me.
