d60s and 35" boggers
rangerdestroyer
im planning on doing a axle swap on a ranger just wondering what you guys think about putting d60s under it with 35" boggers max size. do you think it be to much axle? what kinda clearance issues is there going to be with that small ttire and that big of axle? :dunno:
PlumCrazy
2014 Truck of The Year
179
Millersport, OH
Solid Axle Swap 4x4
People have done it....
-PlumCrazy
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
You could put a lot of horsies behind it without fear of breaking the axles...
The only thing that comes to mind is the weight of each axle. You are gonna need some motor to get those spinning, especially for a DD. Also consider the increase in track width.
Bennybooster
EMT / Paramedic
37
Medford, Oregon.
Diffs will be dragging the ground and the axles weigh about 400 lbs a piece, I wouldn't...
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
If you're gonna romp on it and/or be pushin' a lot of HP, I'd say do it. Like wizkid says, you won't have to worry much about breakage like you would with ½-ton stuff.
projectnitemare
8
Osceola Mills, Pa
396W
the axle really has nothing to do with having the power to spin it. If you want to split hairs yes it may require a little more due to the design. If you were going fullwidth on 1/2 tons then you aren't worried about the width of 1 tons. If you can get a deal on them I would do it. Same amount of effort for the swap and stronger from the start. Yes you are going to be dragging a little more but you have the axle there if you decide to run bigger rubber. Best parts is you can rop it with less fear of breaking.
cdawall
5
Ellsworth AFB
4.0L V6
You would be surprised the D60u's have plenty of clearance. Your weight is low as well 600lbs for a front axle and 400lbs for a rear.
The only worry I would have is the D60 rear. 30 spline rears are weaksauce anything that isn't the D60u has to have the hubs bored to clear 35 spline shafts.
projectnitemare
8
Osceola Mills, Pa
396W
I'd have to agree...skip the D60 on the rear. I sway toward the 14 bolt chevy (gasp) for a rear axle. They are still pretty cheap and can find them pretty easily too. Close tie to that is the Sterling 10.25/10.5. Recent years have brought parts prices down for them and are quite strong as well...both are still stronger than a stock D60 rear.
cdawall
5
Ellsworth AFB
4.0L V6
With 35's the 14B will be the ultimate diff hanger. Sterling 10.25 or D70/D70u would be the best choices if you cannot find a D60u with the big hubs and no neck down shafts.
projectnitemare
8
Osceola Mills, Pa
396W
I'll agree, the 14 bolt will be dragging balls all the time. The price is right on them though. Depending on your skills shave the bottom. The D70, 70U or 80 isn't bad either. My point is overbuild it the 1st time. I just rebuilt a 70U for a friend and I will say it was kinda expensive to do. That seems to be the case for all the newer 1 ton stuff thanks to the diesel kids thinking these axles will hold 1xxx ft/lbs with 40+ inch tires. Reguardless 1 tons with 35s you'll be ahead of the game
cdawall
5
Ellsworth AFB
4.0L V6
I would never build a D80 same issues as with the 14B. Just to big to be useful. The D70u is absolutely great in the fact that it has better clearance than a standard D60 ever could. The 10.25" is very similar in that fact little less clearance than a D60, but roughly the same strength as a D70.
That D60u I rather like smooth bottom slides over rocks without issues. Plenty strong as far as I am concerned and mine was a 32 spline model which isn't necked down. Plenty strong only small part is the actual splines (1.375" at the splines).
projectnitemare
8
Osceola Mills, Pa
396W
I don't think much on size anymore...for anything I use bigger is better. Kinda keep forgetting he's using 35s as well. He'll be good with pretty much any choice using 35s, but keep in mind if you remotely think you'll be going bigger it won't hurt to skimp on axle selection. A good thing to think about if it's for playing in the rocks then yes something with the clearance would be a better choice, mud won't matter as much. My personal opinion is price would talk because aside from the odd ball ones (dana 61s, tow truck axles due to odd shafts, and so on) you can't go wrong.
CodyXLT
Orlando, Florida
Lincoln
4.0 V6, 5.4 V8 Supercharged, 5.4 V8 Triton
You better do a engine swap first...
cdawall
5
Ellsworth AFB
4.0L V6
projectnitemare
8
Osceola Mills, Pa
396W
What does an engine swap have to do with axles? Most all domestic axles reguardless of size require about the same amount of power to spin and it's within 10 horsepower difference least to greatest. The ones that comsume the most are the ones that have the greatest hypod angle. Bigger tires require nothing more than picking the correct axle ratio.
