D44
Rulebreaker
5
Manton,MI
I need the spindals out for my 79 HP44 and I was wondering if a TTB44 is the same from the spindal out. It would be allot easier to find parts off a TTB than a solid axle where I'm at. RB
Rulebreaker
5
Manton,MI
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
Don't quote me on this but I think they are the same. I do believe 70's F-150 brake rotor is the same as the 80's TTB brake rotor less the ABS of course.
Mutant Pony
9
Hersey, Mi
2300
The '79 straight axle spindle has a large 5 bolt pattern. The TTb has a smaller 6 bolt pattern.
The spindles you need are unique to that knuckle. "76-'79 f-150 and Bronco.
I have at least one but, I don't know the condition. I'll have to tear it apart to see. Let me know.
Rulebreaker
5
Manton,MI
I need Everything from the spindle out so anything I can find will be great. So are the bearings, hub, rotor, lockout, and stub shaft the same? RB
