D30 swap questions
tomahawk350
26
Johnstown, PA
Ford Bronco II
In process of doing a D30 swap on a '89 Bronco II. My question is to all that have done it before. What lift coil springs did you use? XJ coils? F150 coils?
Also, What did you do to make the steering work? My D30 came from a 80's cherokee.
thanks,
Jason
NMB2
July 2010 OTOTM Winner
22
Cody, WY
5.0 V8
i used 4" procomp TJ coils with the stock YJ inverted T steering.
tomahawk350
26
Johnstown, PA
Ford Bronco II
What size tires you running? Got any pics?
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
I saw pictures of stock f-150 coils that were going to be used on a D30 swap but the top control arm bracket was up in the engine cross member and the diff. was like 2 inches from hitting the cross member too when he had it under his truck.
I'm going to be using XJ 5.5 inch lift coils when I do my swap, whether they will do the job or not IDK yet.
And what is the Inverted T steering thing?
Snurfer
snowland, Or
im using 7 inch early bronco springs from skyjacker with EB lower coil buckets from bronco graveyard welded to the lower coil perches of the xj D30. with EB lower retainers. for steering links i would just go with chevy 1 ton tie rod ends and ream out the knuckles of the D30. you could use the stock xj steering linkage and use a ranger rod end for the drag link to the pitman arm as the ranger link will thread in to the xj drag link perfectly. i dont think you wanna go anything over 6 inches of lift total if you wanna use the xj steering as its not a "true" y link. but for a budget build it will work
NMB2
22
Cody, WY
5.0 V8
well I dont have a dana30 anymore, i have DAna60's. but this is what it looked like before i swapped.
those were 35's.
tomahawk350
26
Johnstown, PA
Ford Bronco II
Did anyone use XJ lift coils? Good/Bad?
Snurfer
snowland, Or
depends on cab and motor/ weight over the front axle. single cab/b2 with the 2.9 you could use xj coils and be fine. they'll flex a lot better under the lighter truck. supercab with a 4.0 id go with EB coils. i believe that the xj coils are around 230-250 ppi and the EB coils are around 350ppi or so.
the inverted T steering is where the tie-rod connects knuckle to knuckle with the ends UNDER the knuckles and the draglink comes off the passenger side of the tie rod to the pitman arm.
the inverted Y steering attaches the draglink from the pitman arm to the passenger side knuckle with the rod end underneith the knuckle. the tie-rod then attaches from the driver side knuckle to the draglink, like what you would see on the 95-99 cherokees for reference.
tomahawk350
26
Johnstown, PA
Ford Bronco II
thanks. anyone have any pics of the Inverted T steering setup?
NMB2
22
Cody, WY
5.0 V8
tomahawk350
26
Johnstown, PA
Ford Bronco II
let me rephrase: close up pics.... :)
Doom's Day Custom
5
nj
4.0l
Steering Setups found on many 4x4, 4WD Vehicles
Crossover Steering - Drag Link to Opposite Knuckle
This is a common steering setup in solid front axles. The drag link to knuckle type crossover steering is also one of the most ideal aftermarket designs. With the drag link to knuckle type crossover steering, the drag link drops from the base of the pitman arm directly to the passenger side knuckle, either on top of the knuckle or below the knuckle's steering arm. This setup minimizes radial drag link and tie rod play due to ball joint movement. The tie rod connects the passenger side knuckle to the driver side knuckle. With this type of steering setup, keeping the tie rod as close to parallel to the axle will minimize bump steer.
Crossover Steering - Drag Link to opposite end of Tie Rod
Drag link to tie rod crossover steering is one of the most common factory steering systems. With a Drag link to tie rod crossover steering setup, the drag link connects the pitman arm and to a passenger side location directly on the tie rod. As the drag link controls steering by moving the tie rod, the tie rod serves to steer and maintain a parallel distance between the knuckles. This design comes with some inherent play even if all the parts are new and in good shape. To prevent binding , tie rod ends are sphere-shaped allowing rotation in all directions. As steering forces are applied the tie rod is inherently allowed to twist a few degrees forward or rearward. This twisting action allows forces that would have been applied as steering force to give a little and not steer the vehicle or allow the vehicle to wander a little.
V-Link Steering
The V-Link Steering configuration is another common factory steering system. The V-Link Steering configuration is made up with a V style or V shaped design where the driver side tie rod is connected directly to the drag link the connects the pitman arm to the passenger side knuckle. The drag link also serves as the passenger side tie rod. Effectively forming a "V-Link" between the two steering knuckles. The biggest disadvantage of the V-Link steering configuration is that the distance between knuckle steering arms changes as the suspension cycles into compression. The net effect is that the tires will either toe in or toe out during suspension travel. As suspension compresses up into the vehicle, the tires will toe out. As suspension droops away from the vehicle, the tires toe in towards each other. The effects of toe in, toe out with a V-Link type suspension usually as minimal with stock suspension systems but become more exaggerated with modifications, lifts and increased angles applied to the drag link and tie rod.
Re-circulating Ball and Tie Rod
Common for Independent Front Suspension (IFS)
With steering box equipped Independent Front Suspension (IFS) systems where the wheels and steering knuckles move independent of each other, the re-circulating ball and tie rod configuration is commonly used. The re-circulating ball and tie rod configuration uses a tie rod type connecting rod called a centerlink in between the pitman arm on the steering box and a rotating idler arm on the opposite side of the vehicle. Two independent tie rods, one per side, connect the steering knuckles to the centerlink. As the centerlink is moved by the pitman arm, the centerlink moves each tie rod, which move the steering knuckles. This design is optimal for independent front suspensions due to strength over rack and pinion type designs. One draw back to this type of design is the increased number of joints that wear over time. With more joints linking the steering box to the knuckles, a small amount of wear can be exaggerated into steering play. This type of design is also more difficult to lift while maintaining proper steering geometry.
(IFS) Rack-and-Pinion
Rack-and-Pinion Steering systems are the more modern and advanced form of independent front suspension steering systems and are becoming more common in IFS 4x4's over (Saginaw) steering box configurations. The rack-and-pinion steering configuration setup uses a pinion gear at the end of the steering shaft that mates with a geared rack (or track). As the pinion gear is rotated by steering wheel, steering shaft movement, the rack is moved side to side. The rack in turn moves the two tie rods that connect the rack ends to each steering knuckle. Advantages of Rack-and-Pinion steering systems is precision of movement. Disadvantages of the Rack-and-Pinion steering system is a lack of power and durability sometimes needed offroad.
Double Crossover
Similar to the drag link to knuckle type crossover steering, the purpose of the double crossover steering system typically is to get around obstructions to the steering components, gain lift while maintaining steering geometry or to remove feedback to the steering wheel or relieve stress to the steering box.
The double crossover steering system uses a tie rod and a bellcrank as the first from the steering box. This first link between the pitman arm and bellcrank serves to redirect angles or relieve stress or feedback. From the bellcrank, a drag link connect down to the driver side knuckle or sometimes to the main knuckle to knuckle tie rod, similar to the drag link to tie rod crossover type steering system. This in effect allows the drag link to drop to the drive side rather than the passenger side of most drag link / tie rod systems.
dangerranger83
54
Lafayette, IN
The pictures didnt show up. This info needs to be put in the tech library (if it isnt already there).
tomahawk350
26
Johnstown, PA
Ford Bronco II
progress so far...
How how would you guys recommend getting 5-6" of lift in the rear?
