Current Speed Limits - How Does It Handle
donaldcon
19
Lancaster, Oh
Mine gives you whip lash when it shifts to 2nd.
Sent from my SAMSUNG-SM-G891A using Tapatalk
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
Wonder if they adjusted the transmission to keep it from exploding again. Love the bronco 2, not too sure about this stupid transmission, sorry I'd rather have the old 3 speed transmission back, at least I knew it would work properly, at least in my 84 Ranger it did, and it pulled a 14' travel trailer all over the country from 1984 until 1989, and never had an issue, just normal services.
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
I drove my current truck from 1996-2005 with as a 2wd 2.9/5sp/3.73 gears &235/75-15 tires and it was entirely happy at higher speeds. even on 65mph speed limit roads.
I drove the truck back and forth up and down the length of I-476 more times than I care to count, the 2,9 was entirely happy anywhere from 2600-3500rpm for any length of time
I ever tried it....
150,000 miles with several different 2.9 engines in this specific truck:
Because of the way the early Speed-density engine management works fuel consumption
is more related to throttle position than engine rpm, so my method was get the engine spinning by using WOT for as short a time as necessary, then upshift and use as light a foot as possible.
Also somewhere in there Around 2003-2004 I switched to 4.10 gears and achieved my best mileage ever
In the summer of 2007 I converted to 4x4 and switched to a 4.0.
And my observation of the 4.0 engine is that it sucks gas like it has a bullet hole in the tank above 2600rpm
Highway stability requires good shocks and sway-bars.
For shocks I run Bilsteins
I've also gone full urethane on my suspension bushings.
My ride isn't "user friendly", but the truck is utterly predictable...
donaldcon
19
Lancaster, Oh
They 83 cruising 70 no issue.
My bii is as described above me. Predictable but not user friendly. I run no sway bars and stock f150 shocks with eb axles, a 4.0 5speed, 4.88 gears and 35s. I'm cranking around 3500rpm at 70 getting 10mpg in it
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
215/70-R14
Thanks everyone. So it sounds to me like it will be just fine as it is. I guess I was just used to the 84 B2 with the manual transmission being a bit more snappy on takeoff.
