Crankshaft Position Sensor
Broncopower33
Ramona, Ca
On an 89 bronco II with a 2.9,were is the crankshalf position sensor located.
stegomon
20
auburn/minot maine
fords and only
it is in the distributor. i be leave part of it is the modual that plugs in the back and under the dizzy cap acts like the craskshaft position sensor
Strictly speaking, there isn't one.
There is a pickup module inside the distributor. It's a hall effect device that lives under the dis cap. It is more analogous to a cam position sensor, but since the timing can be set manually that signal can function properly for both purposes.
Broncopower33
Ramona, Ca
ok, thanks for the info
No members online now.
