Correct Camber Kit
King17
Jacksonville, FL
i was wondering if anybody had 3" lowered ibeams and new the correct degree to set the wheels straight.
ILLEGALCONCEPTS
4
Pittsburgh PA
2.3 Modified
If you just do beams, you should be OK with the stock eccentrics. I would suggest getting the adjustable ones listed at the top of the page though while you are at it. That way if/when you go lower they will already be there.
James
King17
Jacksonville, FL
The last ranger i had i lowered with the same ibeam and it was a 2.3 and the camber was off. They said they couldnt get a true alignment because the camber wouldnt sit straight. I then ordered the adjustable ones and they said it needed to be more than 2.5 degrees.
Im not going any lower but it will sit lower when i swap my 4.0 for the 5.0.
ILLEGALCONCEPTS
4
Pittsburgh PA
2.3 Modified
Hell I didn't have any problems with mine and I have the 2'' coils and the 3'' beams. Even when I just had the 2'' coils, I still had the stock eccentrics and they were able to put it in spec.
James
ems
minneapolis
2.3
what kind of beams did you get. dream beams had the proper camber adjustment
slammedxonair
Vermilion, OH
91 and 00
if you have a 89-97 go to napa and get the eccentrics part # 264-3950 +-4 degree camber caster adjusters and then take the truck to an alignment shop. Absolutly no reason the truck cant be aligned perfict.
multiranger
Praise the Lowerd!
MTOTM Winner
17
Loganville GA
Using the Dream Beams: What if the truck had a 2.3 but it was changed to a 4.0? Should the springs and eccentrics from the 4.0 truck be installed into the one with the 2.3 or does it matter?
slammedxonair
Vermilion, OH
91 and 00
you might want to use the 4.0 springs, but there is only 1 part number for ranger aftermarket lowering coils so I dont know if ford had different springs or not. As for eccentrics get the adjustable ones from napa.
multiranger
Praise the Lowerd!
MTOTM Winner
17
Loganville GA
I went from a 2.3 to a 4.0 with stock I beams.. had to change springs and eccentrics to get the wheels right... never had it checked but the tires wore like they should. The 2.3 truck was a 89.. the 4.0 was a 92... The esscentrics were very different... I agree with going with the nappa parts..
volrath
menomonie, WI
FORD
2.9L
true that. i would get the eccentrics right away. some off road shops may be more able to use the eccentrics properly. some shop around were i live wouldn't use them. the off road shop near me is used to them and knows how to use them right. might be worth a few phone calls
Nick
Altoona. Pa
ok guys, i lifted a ranger 1990 by making a 2 in plug and bolting it on a 2wd. will this part above work on my ranger for lift as well? the other kits are only 2.1/4 deg
slammedxonair
Vermilion, OH
91 and 00
The part number I listed above is +-4 degrees camber/caster it is the max you can get for a ranger.
doorgunner
Lab Rat for V.A. hospital
MTOTM Winner
2009 Truck of The Year
516
New Orleans (8' below sea level & sinking)
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
Good job of keeping up with a 2 year old thread!!!!!!!!!!
sorry.......4 year old thread.....
slammedxonair
Vermilion, OH
91 and 00
Somebody obviously used the search function (as people should on forums) and then asked a new question about the same topic, that bumped the thread up as a new post (along with the other thread you posted in) so I answered the questions. What is the problem? I'm not digging up old threads and answering questions from years ago. Read the dates on the recent questions in the threads.
