American1990
- Dec 10, 2010
- 0
- Conyers, Ga
- Ford
- Engine Size
- 4.0
- My credo
- Build it, Break it, Re-build it stronger.
Ok guys, I did a 4.0 swap awhile ago and I've been using the FM146behind my 4.0 it held up fine but now I got a transmission to replace it with, a Toyo Koygo 5 speed, that came from a 4.0 explorer now, I know there a length difference between the FM and Toyo of like 2-3 inches, so my ideas are the following (P.S. a M50D-R1 4x4 version nearly IMPOSSIBLE to come by where I live) SO idea 1) find a ranger with the same transmission and wheel base and take the drive shaft 2) I've wanted to do a Chevy leaf spring swap for the lift and springs,so if i did that and moved the front shackles would that compensate for the distance of space needed for the drive shaft or would I need to move all four shackles to compensate for it? 3) Am i just crazy? I got the transmission out of a ford explorer control trac 4wd 1991 eddie bauer 4.0 ohv Toyo-Kogyo 5 speed... was the toyo kogyo ever put behind the 4.0? The trans code came up T when i looked it up it was 1992+ model T were automatic a4ld ones. But nothing for the T code for 1991 and below manual of before 92+. The explore was stock manual so i know it was not a automatic. The fm146 and M50D are the same length and the toyo is shorter, I believe this is atoyo, I had to move cross member and lengthen my drive shaft. Ill post picture when i can, is this odd?
