Complete OEM Cruise Control Installation
mfernandes
7
Disclaimer:
The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums.
Just get all the hardware, tools and take your time. Its simpler than what it seems!
Original Poster:
mfernandes: Matias Fernandes, Paysandu, Uruguay (South America)
Difficulty:
4 out of 10.
Time to install:
2 hours aprox.
Brief Explanation:
This is a guide on how to install, from scratch, the Cruise Control on a 1996 Ranger, XLT V6 3.0 liter engine. My truck came with no cruise control from factory, but the system was totaly prewired.
All the parts are original Ford or Motorcraft. I took the time and patience to get every component, screw and any hardware to make a nice, clean installation.
Tools Needed:
- 8 and 10 mm socket
- philips and flat screwdrivers
- Steering wheel universal extraction tool.
- T-40 Torx screwdriver (to remove the steering wheel)
Parts Needed:
- Cruise Control servo
- Cruise Control servo cable (engine and year specific)
- Cruise Control servo cable plastic retainer
- New clockspring with C/C connections (part #F76A-14A664-GB)
- New Brake Master Cylinder with C/C deactivation switch (part #F67Z-2140-JA)
- Steering wheel C/C pods or buttons
- Back plastic panel on the steering wheel (with the cut-outs for the C/C pods) or simply swap the steering wheel)
PART 1- IS MY TRUCK PREWIRED?
To see if your Ranger came prewired from factory for the Cruise Control (C/C) you will have to check:
1.1- Under the hood: on front right fender, between the windshield washer reservour tank and the cab fan; look for a large 10-pin black connector, attached to the fender and offcourse, unused. (see pic 1 below).
1.2- Under the dashboard: remove your kick panel and then she metal shield behind it. Check for a yelow plastic tube. This tube ends on 2 connectors, a brown one and a grey one. The grey is for the Air-Bag while the brown one is for the horn, ground and also, the C/C switches. You are prewired if this brown connector has 6 incoming wires. (See pic 2 below)
1.3- On the Master Brake Cylinder: check for an unused plug with 2 wires
Pic 1: Connector on the RH fender:
Pic 2: Connector under the dash: See the brown connector? It has 6 incoming wires and only 3 outgoing. This is that the truck is prewired on the steering column, as those extra wires are the wiring for the C/C switches on the steering wheel.
Now that we are sure our truck is prewired for the C/C, we can start mounting all the hardware on the truck.
PART 2: MOUNTING ON THE STEERING COLUMN:
2.1- DISCONNECT BOTH POLES ON THE BATTERY AND WAIT FOR AT LEAST 15-20 MINUTES. We will be working with the Airbag system, so fully disconnect the battery and wait till the system gets discharged.
2.2- Remove the kick panel, metal shield underneeth and the steering column trim.
2.3- Remove the bolt covers on each side of the steering wheel
2.4- Remove both 8mm nuts on each side of the steering wheel, then unplug and remove the airbag. Set it a side on a flat, non static surface facing UP.
2.5- Unplug the horn wires on the steering wheel.
2.6- Remove the steering wheel nut with an T-40 screwdriver
2.7- With the universal steering wheel extraction tool, remove the steering wheel.
2.8- Disconnect both grey and brown plugs under the steering wheel column (see pic 3).
Pic 3: original brown and grey connectors:
2.9- Disconnect the wire going to the ignition cylinder (light blue blug, see pic 4 below)
Pic 4: wire on the ignition cylinder:
2.10- Remove all the mounting clips the the yelow tube
2.11- Remove the clockspring assy. There are 2 tabs on each side, pull them and remove the clockspring with the yelow tube assy. See pic 5
Pic 5: original clockspring and yellow tube on the steering column:
2.12- Once removed, put in place the new clockspring. Attach it firmly to both tabs. Route the yelow tube underneath the column, attaching all the mounting clips and also, the light blue connector on the ignition switch
2.13- Reconnect the brown and grey plug on the steering column. See pic 6.
Pic 6: new plugs under the steering wheel column:
Before installing the new steering wheel with the C/C switches, we have to pull the yelow retainer on the clockspring. This retainer keeps the clockspring centered and in place, so:
2.14- Pull the yellow tab and try not to move the clockspring. See pic 7.
Pic 7: yellow retaining clip on new clockspring:
2.15- Reinstall the new steering wheel. Theres a mark so you cant missalign it. Put the nut in place and tighten it. See pics 8 and 9.
Pic 8:
Pic 9:
2.16- Connect the cruise control connector on the new clockspring. See pic 10
Pic 10: connections on the steering wheel to the new clockspring
2.17- Place and connect the airbag to the new clockspring.
2.18- Reassembly all the panels, we are done with the interior
PART 3: MOUNTING UNDER THE HOOD:
3.1- Mount the Cruise Control servo (with its metal bracket) to the RH fender. Tighten the 10mm bolt.
3.2- Route the C/C cable over the engine and route it to the accelerator cable
3.3- On the accelerator cable bracket, you will be able to see an unused spot for the C/C cable. This fit in only one direction. Firmly attach the cable to its spot and double check it wont come out. Its very straight fowardm you can go wrong with this.
3.4. Place the C/C cable retaining clip and place the cable in place.
3.5- The most difficult part of this installation is replacing the master brake cylinder, as you will have to refill and purge offcourse with new fluid.
3.6- Remove the original brake master cylinder and place the new one.
3.7- Connect the Cruise Contro deactivation switch and plug the black connector, which should have been there with the truck (step 1.3)
3.8- Fill with brake fluid and purge the system
Done with the installation. In my truck I have to modify absolutely nothing and the system works like it should. Also, and as important, it deactivates perfectly, whenever I press the brakes and /or clutch.
This was one of the nices mods I made to my truck, woth every dollar and minute invested!!!!!!
Colin
182
ON Canada
Mazda
Just wanted to add an update to this article.
Just finished the install on my truck (04 B4000 2wd auto) and it works great. I believe you can do this on trucks up to 06. You will need to use buttons and clockspring from an 04-06 and the wheel from an 04-08. Otherwise follow the rest of the write up
rangerman1994
Pennsylvania
Disclaimer:
Original Poster:
Difficulty:
4 out of 10.
Time to install:
2 hours aprox.
Brief Explanation:
Tools Needed:
Parts Needed:
Pic 8:
Pic 9:
I have a 2005 edge that doesn't have cruise control. And I have a 2004 xlt with cruise control that is a parts truck. Would it be best to pull the column out of the other truck which would also give me tilt column or are they not interchangeable. Or would it be better to take individual parts? As far as being prewired I do not see a ten pin plug under the hood as shown in the pictures but I do see the wiring under the dash that was posted in the photos.
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I don't know enough to give you a good answer. It should be all plug and play being only a year apart. But I never did the project, so I may be missing something.
rangerman1994
Pennsylvania
That would be fantastic if it was. However I don't have the ten pin plug on the fender which I believe plugs into the cruise control servo. I have the servo and the plug that plugs into it from my parts truck, but I do not have anywhere to hook the wires to unless I wire it all myself.
Colin
182
ON Canada
Mazda
If you don't have the plug under the hood I wouldn't bother
Jim H
Camas wa.
Ford Ranger XLT
I did this modification on my 98 XLT 3.0 with manual 5 speed. Everything works good except the clutch disengagement. If I push the clutch to down shift for a hill. The engine just revs wide open. Does anyone know if there is a different clutch switch for manual cruise control models. The original clutch switch for safety start works and has not been bypassed. And the cruise will disengage with the brake. But not the clutch. Any ideas?
Colin
182
ON Canada
Mazda
I didn't see a different switch listed. How many wires are coming out of the connector? Try to find a wiring diagram
Jim H
Camas wa.
Ford Ranger XLT
I have 7 wires coming out of the switch. Chilton's manual says the switch performes three functions. Depress to the floor to start, cuts speed control when pressed and provides a fuel control signal to the EEC system. Rock Auto only lists one switch. Nothing separate for cruise control. Maybe the switch is partially bad after 25 years. I will try replacing the switch.
Colin
182
ON Canada
Mazda
Possibly, try to follow the wire on the diagram and see if it hits a relay or something like that. Is your cruise control servo from a manual truck?
Jim H
Camas wa.
Ford Ranger XLT
It's the switch! It works intermittently. If I press the clutch normally it doesn't cut out. If I do a quick jab at the top it will cut the cruise.
Colin
182
ON Canada
Mazda
Glad you figured it out, guess you need a new switch
