cold start
FRENCHMan
FRANCE
Hello everyone,
:icon_confused: I noticed when it's very cold (last night we -10 ° for some of you this is nothing).
impossible morning as the truck starts.
I am forced to unplug the cable from the batery... and then back after 10 minutes i plug the cable and the truck starts :dunno:
if you could give me some assistance please thank you very much
:icon_cheers::icon_cheers::icon_cheers:
--weezl--
June 2011 OTOTM Winner
Law Enforcement
182
hell
hold on, so you went to start the truck when it was damn cold, you turn the key, nothing happens, you disconnect the battery from the truck, for 10 minutes, reconnect, try again, and it works no problem?
what did it do when you tried the first time, did it turn over but not catch, did it click, did the dash lights come on?
FRENCHMan
FRANCE
:dunno: I put the key in the ignition. I try the engine not start , everything else light function. autoradio. klaxon.juste engine does not start
--weezl--
Law Enforcement
182
hell
ok, when you turned the key, did it turn over? or was it like you weren't turning the ignition at all?
FRENCHMan
FRANCE
Yes the engine turns but will not start :icon_confused:
kimcrwbr1
46
maplevalley WA
2.8l
lightly clean the battery terminals and clamps with sandpaper and get the clamps good and tite. If all you tuoched was the trminals then that was the problem. let us know either way.
FRENCHMan
FRANCE
I think that's not it. everything is clean.
The more bizarre, I turned on the ignition, the engine turns but will not start.
I waited 5 minutes.
after he started
Psychopete
29
FW, IN
Not sure what year you have and how similar your truck's wiring is, but my '88 2.9L Ranger had a single small gauge wire ground connector off the battery. Bad connection with that ground wire can cause the engine to turn over, but not start.
BlackBII
Ranger Custom
Truck of Month
982
UT
That was probably the ground for the computer, it goes directly to the battery.
Mr FRENCH...
When your truck wont start, is it because it is lacking Fuel or Spark?
That would help tremendously. I have had this issue with my Ranger, the fuel pump will sometimes not turn on when its cold, have to turn the key on and off a few times.
FRENCHMan
FRANCE
Mr FRENCH...
:icon_thumby:I agree with you
I waited 5 minutes.
after he started
Thank you very much Mister BlackBII
FRENCHMan
FRANCE
:yahoo: By dint of searching, I finally found it.
my brother took the truck and when he put a little gasoline.
it to fill with a mixture of 10% ethanol.
now I have recovered normal essence
and now it's ok
:icon_bounceblue::icon_bounceblue:
No members online now.
