Coil Spring spacer problem
08rangerXL
Mandeville, LA
2.3
I put a 3" coil spring spacer on my 08 2wd ranger. About 2 weeks later, it settled about an inch which made it ride really bouncy. I put the rancho rs5000 maximum travel shocks which said 1" to 2.5" lifts and they bottom out. Any ideas on what could've caused this?
Snal
Sacramento
I've been told the most you can put is a 2" spacer or you'll have to get an after market control arm to compensate for the extra spring length
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Did you get it aligned after installation?
08rangerXL
Mandeville, LA
2.3
Well I kinda ghetto rigged the shocks to make them not bottom out anymore but I guess I have to live with the front being slightly lower than the back again.
NickRanger89
Tampa, FL
What spacers did you use? I installed 2in spacers a few months ago and they haven't settled. I don't think it would if they were aluminum. Maybe its the way you installed them or seated the springs? You installed them with the open part facing the outside right?
06RangerXLT
54
Georgetown Ontario
a spacer should not settle. sounds to me like you broke one. spacers should have zero play or compression.
pillen140
45
winston-salem, NC
Shitty poly ones do settle over time..... they mushroom out til the break. You're seriously way better of stacking steel washers than the spacers. Took me almost a year to break mine.
06RangerXLT
54
Georgetown Ontario
he cant stack washers. The spacer is a convex/concave horseshoe type that sits on the top or bottom of the coil. what is really better in spindles and replacement coils.
