Coil spring bucket replacement
mp3deviant721
24
Eau Claire, WI
2.3l of fury
I just have a few questions about the right bolts for this job. I was told that a 12mm bolt will fit the rivet holes perfectly. But I was wondering what length I should be getting. I was also wondering if a fully threaded bolt vs. a bolt with an unthreaded portion would be ok to use.
envious8420
8
murphysboro il
2.3
inch and a half, with washers(2) and a lock washer. grade 8 or higher
alwaysFlOoReD
5,172
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
^^^ I did the same; I used the shortest 1/2" Grade 8 that had a non-threaded shank. I used two 7/16" washers approximately 1/8" thick plus a lock washer so the nut didn't bottom out on the shank. I drilled the holes out to 1/2" with a step-drill;
http://www.canadiantire.ca/AST/browse/6/Tools/PowerToolAccessories/DrillBitsSetsAccessories/PRD~0540690P/Irwin%2BUnibit%2BStep%2BDrill%2BBit.jsp?locale=en
Good luck,
Richard
