coil spacers
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
ok guys i just wanted to make sure first b4 i go and make them... if i only do 1 1/2 inch i dont have to get drop brackets right? i just wanna clear a little bit bigger of a tire.
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
1½" spacers = 2¼" lift. Might be pushing it pretty close, but it's possible it may work.
To be a little on the safer side, I'd go with 1¼" thick spacers.
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
thanks i didnt know that i thought it was the same amount of lift as the coil spacer is that hels me alot.
94xlt4.0
ASE Certified Tech
san diego, ca
4.0, 2.9, 4.0
you also need to remember the coils have probably sagged quite a bit if they are still original. with the 1½" spacers you will most likely be fine still. i have 2 inch spacers and was still alignable
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
ok so come to find out the guy that was gonna make them for me doesnt know how so if someone could help me out on how to meke them i would appreciate it
sirfunkeybut
stacked washers welded?
Maniac
Frenchville, PA
2.9L v6
i put 2 inch coil spacers on mine and neededdrop brackets cuz the frontend was too outta wack to get aligned
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
the only problem im haveing sirfunky is what size do i use as in size around
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
thamk you 4x4 that helped alot
