clutch pedle went limp and cant shift..
rangerty
lancaster
Hey all this is the first time i have had something like this happen..
i have a 96' 4.0 2wd
first off i just hand the engine rebuilt and when the motor was out i put in a new clutch.
with in the last few days i had noticed that it was just a bit harder to get it into gear. one night as i was driving home i stopped at a light and there was NOTHING getting it into first.. at that light i was able to get it into second and then into 3rd.. then another light. at that one i had to jump into 3rd right off the bat and made it the rest of the way home.
i checked the Dot.3 and it seemed to be filled.. any ideas on what i should trouble shoot????
thanks all.
BRUTUS_T_HOG
ASE Certified Tech
36
Rainier, OR
2.3L
bad slave cyl or bad master cyl, or both.
does pumping the pedal help?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Bummer.. Should have replaced the slave when you replaced the clutch..
Been there, done that...
Blueranger99
lebanon, pa
4.0l v6, k&n box filter- this thing sucks... air
check out the transmission forum, theres like 3 threads about this same problem including the one i started. try bleeding your system, thats what i did and ive been doin fine for 1 1/2 weeks. mine is the slave.
rangerty
lancaster
i did try pumping it.. still nothing..
that brings me to my next question... is the slave inside the trans?? =-(
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Yes, it is an internal slave.
MagnaV30
Vancouver, British columbia, Canada
2.9L
Not inside the transmission, but inside the bellhousing.
Regardless, still means your dropping the transmission to get to it.
rangerty
lancaster
bummer!!.... but thanks guys!!!!!!!!! :icon_cheers:
Blueranger99
lebanon, pa
did i really say to check out the transmission forum when its in the transmission forum or did it get moved from gen. disc.? i must be losin it.
rangerty
lancaster
lol no your good bud! it was in the v6 4.0 first... :icon_thumby:
