Clogged Cat
gminor69er
Auburn, Wa
what are the syptoms of a clogged cat, does it feel like no power and when you give it gas it doesent want to go faster? Also can the back pressure of a clogged cat make it sound sucking (blowing pressue).
Thanks
Stumpy
Tacoma area, Washington
Really it will just bog down under load from my experience. You'll mainly notice it on top end. I'm sure some other guys will chime in with their experience.
90rangersuper
Pittsville,WI
i had a 99 astro van, the cat became clogged after 290,000 miles, i could go no faster than 40 mph floored, after running it you can take one of those IR temp meters and the temp should be really high or even glowing, basically, a major loss of power will happen
chittybangbang
Aurora Ohio
2.9
You might notice a pinging sound from your underside first.Then the truck will just bog down and have zero power.Thats what happened to my E250 @51k
UrbanRedneckKid
17
Cass Co, Missouri
X2.. Same thing happend to my old B2 at 155K w/ a pugged cat
Although, my 94 4.0 did the same thing and it turned out to be a weak fuel pump
racsan
4,443
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
i had a '82 fairmont with the 200 I-6. the converter plugged on it and it wouldnt go over 50 mph.
________
Yamaha V50
nismotunedgtr
USA
You will also loose vacuum on acceleration / throttle.
