markopolo
- Sep 1, 2009
- 0
- Age
- 35
- SEMO
- ford
- Engine Size
- 3.0
So here is what I have going on. I have a 94 3.0 5speed 4x4. When I start it, it will fire right up run good and then die or sometimes try to die. Then upon restarting it will idle down to around 500rpm and run rough, almost like its cammed. Take it for a drive and it will run halfway decent. When its under a load it will bog down then take off similar to turbo lag. The weird part is when I try to retrieve codes I cant get any out of it. I have a jumper between the eec connector and the test lead. When I have the jumper in place it doesn't do the surging under a load. It runs great actually. It also idles high (1200-1500rpm) when the jumper is in place. I would leave the jumper in all the time but its a pain to start when at temp. It dies or tries to die several times before it levels out.
I was just wondering if anybody out there has heard/seen of this....
