"cats"
bknighton1
V6 3.0
i have a 2001 3.0L and i was looking under the truck and saw my truck has three cats why is this and wont that just make it even more quiet?? Most trucks ive seen have two cats or even one!!
mhughes165
9
302
most of them are like that now, everyone wants more quiet and more "emissions friendly"
elgato
My 04 3.0 has three also. One on each side in a Y pipe that feeds into a third single. The o2 sensors are only before and after the front two. I just replaced them with Magnaflows that appear to be a bit louder than stock.
bknighton1
V6 3.0
about how much would it cost to get flowmaster 40 series installed and to only have one cat! ??
85_Ranger4x4
17,953
SW Iowa
You would save a lot of money by leaving the cats alone and just playing with the muffler. Modern cats are pretty low restriction.
I would guess somewhere between $200-300 to get a catback put on. Add $150-200 if you want to change the cat as well.
mhughes165
9
302
not that cheap on the newer vehicles, cats for new vehicles are EXPENSIVE as HELL
85_Ranger4x4
17,953
SW Iowa
Aftermarket high flows are still pretty cheap though.
Replacing a good cat system with a brand new stock system doesn't make much sense.
mhughes165
9
302
85_Ranger4x4
17,953
SW Iowa
That is a direct fit replacement cat system, the same thing that he has now but aftermarket. Note the last line in the description:
These converters are designed to exact OE specifications and are available for the most popular vehicle makes and models.
When most people get aftermarket cats it is something more like this:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MPE-53005CA&N=700+4294923429+4294838974+400636+115&autoview=sku
mhughes165
9
302
but those would require a 100% custom exhaust system, keep in mind, they have oxygen sensors in multiple places on that y pipe, before and after cats, so u would need a high dollar labor instesive exhaust to make use of aftermarket high flow cats
ranger
Pittsburgh,Pa
Mazda B4000
2.9L
how do you tell how many cats you have
RangerJustin
Simi Valley, CA
i dont know about all your areas, but cats are getting stolen out here more frequently since their value is quite high...
bknighton1
V6 3.0
so i would be better off sticking with the 3 stock cats and getting a flowmaster 40 series or something of that sort? I've seen them online for about 80.00 so how come if you go to a shop they are around 300.00 installed? are they just jacking the prices way up and charging aton for labor??
mhughes165
9
302
yep, its what shops do, didnt ya know
85_Ranger4x4
17,953
SW Iowa
I would stay with the stock cats.
Shops will charge a little more for the muffler than you will get online, and then an hour or two to put in using the existing pipe.
I bought my mufflers and tips for my F-150 and took them to the shop and had them put on, no problem.
