Catalytic converter delete
Chapap
672
NW Florida
Ford Ranger XLT
2.3
1.5” till I get these springs replaced
225-70-R14
Yep, new ignition components fixed all the missing. Wouldn’t say I gained power, but it’s nice and smooth now. Surprised I didn’t get a light.
Chapap
672
NW Florida
Ford Ranger XLT
2.3
225-70-R14
Well the Pick and Pull by my can’t sell catalytic converters. I’ve read that the Feds require used cats to be tested and certified to be sold. So that’s out. Rock Auto has that section of pipe for like $120. Any thoughts as to the cheapest option to get this pipe fixed? Really not too worried about the environmental part, just the noise. I’m sure that rule hurts the environment more than it helps.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Dude a universal cat is like $50 bucks... It's cheaper to fix it right.
Chapap
672
NW Florida
Ford Ranger XLT
2.3
225-70-R14
Ya I’ve found where I can get just cats, but I am looking for the whole pipe section between the header and resonator section too. That way I can just bolt it up and don’t need to do any cutting and whatnot
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Best bet in that case is to hit up an exhaust shop. They will usually make the pipe fairly cheap and just tell them to throw a cheapo universal cat on it. Junkyards can't sell cats, transmission pans, or diff covers by federal law.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Pretty sure Rock Auto sells the cat assembly that bolts in between between y pipe and muffler. its flanged w/ bolts on both ends. My 4.0 ohv is at least.
Chapap
672
NW Florida
Ford Ranger XLT
2.3
225-70-R14
transmission pans and diff covers??!!?!? Why on earth is that a rule?
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I have no confirmation of this but I was told it's because people taking trans pans and diff covers off in a junkyard means they are obviously dumping oil on the ground. I can also see it being frowned upon by the people who run/own junkyards as well since once someone takes the pan or cover off no one is going to want to buy the whole diff or transmission now that's it's open and exposed to the elements. Would you rather sell a 5 dollar pan or a 300 dollar transmission?
sgtsandman
Aircraft Fuel Tank Diver
12,772
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
When I replaced my driver’s side cat, I think it was around $200 from Rock Auto. So far it has worked no problem. Of course, PA is one of the 49 or whatever Federal emissions states. If you have California emissions on your truck, you might be stuck complying to that standard and the extra cost and limitations.
Part of the reason it was so inexpensive is that the core isn’t solid. There is a section before the aft O2 sensor and (at least it looks like) after. I think the OEM was a solid core though out the cat.
Since it’s sold through Rock Auto, I’m sure it’s legal but it might last as long as the much more expensive OEM one should.
Roert42
5,028
Kintersville, PA
Ranger XLT
4.0 SOHC
Pa is a California “CARB” compliant state, not federal, I do believe.
I know that a lot of junk yards drain all the fluids before storing the vehicles.
I have seen it where the yard will opt to punch a whole in the trans pan instead pulling the pan off to drain. Thus requiring you to byo transmission pan.
sgtsandman
12,772
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
PA is not, thank God. Living where emissions testing is required not only by the state but in order for me to get on base to work, things are bad enough without throwing CARB compliance into the mix.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
PA is indeed a CARB state. All new vehicles sold in PA need to be CARB compliant since 2008.
They just don't enforce the rules on replacement cats and vehicle modifications like California does. If it has a cat and passes all other test it's fine whether it's an aftermarket universal non CARB cat or an OEM CARB certified cat though legally a grey area to use a non certified cat...
Here in NJ we are also a CARB state but since the only inspection we have is an OBD2 CEL test people do whatever the hell they want since no one is inspecting any aspects of the CARB certification after the vehicle is manufactured. Your car could literally be on fire when you drive up to the inspection station, as long as the scanner shows no codes you pass inspection.
Chapap
672
NW Florida
Ford Ranger XLT
2.3
225-70-R14
Here in FL, I’ve never experienced any manor of vehicle inspection so I really know nothing about any of these regs. When you register your car here, the car doesn’t even have to exist. Just have a title, give them tax, and you’re set. You might get pulled over if you’re rolling coal so bad it obstructs the visibility of cars behind you, but that’s about it.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
State regs vary wildly on how they handle inspections, pollution standards, and all that but federal regs are pretty simple to remember... Don't screw with the emissions equipment no matter what state you're in. :ROFLMAO:
Roert42
5,028
Kintersville, PA
Ranger XLT
4.0 SOHC
What Dirtman said. Pennsilvania's clean vehicle program requires all vehicles newer the MY2008 be built to CARB standards, I believe a lot of states are the same and I would be surprised if manufactures offered non CARB versions of their vehicles for sale. They are not 100% CARB compliant in the matter of regular inspections, just requiring to meet the standards when new.
