catalytic converter bolts
dragster557
I cannot get the top nut to turn on a 1989 b2.Cannot find the right socket to grip the nut just right.Help please.
Bronco_Chuck
Los Lunas, NM
84, 86 & 89
2.8 & 2.9
time to get the blue tip wrench. it will come right of, easy as pie.
cargs
FORD
he means cut them off (with a torch). I cut mine off with a zip disk. i replaced the studs with stainless steel bolts. makes it much easier to get off in the future.
good luck.
59bisquik
April 2011 OTOTM Winner
Solid Axle Swap 4x4
I got them hot and soaked them with PB Blaster for a few days. They came off really easy after that. I think I used a swivel and a couple extensions.
dragster557
What size socket did you use.
Ranger44
23
Illinois
FORD
4.0 OHV
Cut off wheel or torch are the correct sizes.
Chances are, those bolts are so corroded there isn't a correct size. And every time you put a smaller size on and try it, it'll just round it off.
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
The "bolts" on the front of the catalytic converter aren't "bolts"
they are studs.
Infact they are like miniature wheelstuds with a knurled section and a domed head on the back side.
They can simply be driven out of the cat flange and replaced with conventional bolts.
what "size" they originally were is irrelevant, because the nuts rust and shrink
in size so they can be any size from the original 15mm rown to "gone"
Cut them off and start over.
this application cries for a stainless steel bolt.
AD
xploridaho
Those are some good tips, I will have to remember them.
