Can’t bleed after disk swap
Dantheman1540
467
Florida
I put SN95 mustang disks on my ranger months ago and had trouble bleeding them then as I am having now. Basically I cannot get any fluid to come out of the bleed. If I crack the lines almost anywhere else in the system I get fluid, although it’s not a super strong jet when cracked and the pedal is pumped.
Right before I put these disks in my drums were working and would kick the ABS on when activated on dirt. Now the rears do absolutely nothing whatsoever, which includes the parking brake despite it being fully activated.
Anyone have a similar problem? I even bought new calipers today and I’m still having the same issue.
Josh B
1,988
Oklahoma
Any chance those lines had some gunk in em?
Dantheman1540
467
Florida
I cleaned them with brake fluid before installing, the soft lines are all new stainless lines, and even now if I disconnect the line at the ABS modulator and shoot brake clean it jets right out the soft line that attaches to the caliper.
So either my ABS modulator died suddenly or does not push enough pressure to the rear. The master is failing to send enough pressure to the rear. Or the calipers are for some reason not working right.
However if I crack the line on the master which leads to the rear it squirts out a good bit of fluid making me believe that the master is okay. Although there’s no way to really quantify if the amount coming out is enough.
8,372
Front line on Master goes to the rear brakes
With foot off the brake pedal all lines are open from master to each wheel, so opening a bleeder should get fluid Gravity Bleeding from the Master's reservoir
ABS valve limits flow when activated, to prevent lock up, so are wide open when not activated
Take cap off the master just to make sure Vented Cap is not clogged
Open a front wheel caliper bleeder and see what kind of flow you get
No air can get in
Its just gravity, i.e. fluid running downhill, but should drip out pretty well
Then try rear, should be the same flow as front, master is the same height above caliper, lol
ABS valves can get crud in them, many replace them with an adjustable proportioning valve
Leave ABS valve plugged in so ABS light stays off, if you do this
Dantheman1540
467
Florida
So I have already tested to see if the bleeders leak any fluid when left open and they do not. When I pull the lines off the caliper they will leak a little initially but stop fairly quickly, meaning there is some sort of blockage in the ABS correct?
I do not want to lose rear abs so I can replace it with a new module if that is indeed the culprit.
RobbieD
2.9l Mafia
3,559
Georgia
Is this a 1994 Ranger? I thought that '94s had RABS only, not ABS on all four wheels (which Explorers do have). Mainly curious what antilock setup your truck has.
Dantheman1540
467
Florida
Correct it’s a 1994 with rear abs only
RobbieD
2.9l Mafia
3,559
Georgia
Sorry, brain fart on my end. When you said checked flow to the rears from "ABS modulator" you're talking about the one on the frame.
Dantheman1540
467
Florida
Yep driver side, pretty crappy spot.
Dantheman1540
467
Florida
Come to think of it, yes when I disconnected the line after the ABS modulator and had someone press the pedal it would squirt a small amount. But when the pedal wasn’t pressed it didn’t really leak anymore with gravity. Leading further to thinking it’s the modulator
Bgunner
1,095
Western Mass.
Ford/Ranger XLT
225/70/R15
if you happen to have the items on hand you could try a bypass around the modulator and see if that makes a difference. This would tell you if the modulator is stuck closed or partially stuck.
snoranger
Professional money waster
ASE Certified Tech
13,721
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Your RABS module is clogged/bad. You may have some luck pulling it, disassembling it, cleaning it, and reinstalling it… you may not.
My recommendation is to either replace the RABS module or install an adjustable proportioning valve in its place (and adjust it for your new brakes.)
Dantheman1540
467
Florida
That’s too much laying on my back with brake fluid dripping on me. I’m getting lazy as I age.
I’d really like it to work like factory so I’ll just pickup a new rebuilt one, should last 29 years like this one has. I find it so coincidental that it poohed the sheets exactly during my disk swap tho.
New one will be here Friday! That rebuild is tempting but idk that it’s worth the hassle of possibly having to install and remove twice if I mess it up somehow.
sgtsandman
Aircraft Fuel Tank Diver
12,753
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
You could rebuild it and keep it as a spare for a while. Then sell it later if it seems to be taking up too much space or is not needed.
