- Aug 17, 2007
- 4,447
- central ohio
- ford/escape
- Engine Type
- 2.5 (4 Cylinder)
- Engine Size
- 2.5/151 I-4
- 2WD / 4WD
- 2WD
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
ive got a magnetic angle guage i could just stick to the rotor to check the camber, but whats the angle im looking for? id assume id want it to be a slight bit to the positive side, im mainly concerned with my drivers side axle that i just replaced, the passenger side seems fine, would they both use the same amount of camber? im thinking all i have to do is loosen the pinch bolt & then rotate that bushing with the hex head on it until i get the reading im wanting. i measured for toe off the rotors and that worked fine for me. i have put in new ball joints on my junkyard axle. the truck im doing it on is my '93
