cam and injector help
offroadranger
hey guys,
I have a 99 ranger 2.5l. So far it has: custom intake, full length "race" header, no egr, ported head and lower intake manifold, and a jet chip.
What I want to do next is add a cam and the 19lb injectors....
Can someone help me out with camshaft selection? What cam to go with for my setup? Do I need new valve springs? If so, which ones?
And on the injectors....I read somewhere you can drill out the mass air flow sampling tube to "fool" the computer into adjusting for the larger injectors...then I read somewhere else this is not the correct way to do it, and you dont gain anything....is having the computer flashed/dyno tuned the way to go? Who can do that?
this is a off road race truck that runs at 4-6000rpm for 4+ hours at a time and seems like it could really benefit from the larger injectors if they can be tuned properly.....I am just clueless when it come to tuning engines. I can install any part you throw at me, but matching parts and getting them dialed in I have trouble with. I think its the lack of patience lol.
Thanks!!!
Dave R
In the snow belt
Kaiser
Unfortunately, since you have a 'newer' motor, you have the smaller valve stems, which require the unique smaller tipped roller followers, requiring you to use a roller cam, which is not cheap.
Upping the injector size and drilling out the MAF sampling tube works well.
Mutant Pony
9
Hersey, Mi
2300
Racer Walsh will set you up with springs to match the cam you purchase from them. They have complete kits that have everything you need. The prices are a little better than Esslinger.
offroadranger
Funny thing is I called racer walsh and they told me I could'nt use an aftermarket cam, because my engine has a cam position sensor and it would'nt run right.....maybe I just need to talk to someone else over there....does'nt make any sense to me...
what size do you drill the maf tube out too?
thanks guys
Mutant Pony
9
Hersey, Mi
2300
No. They're right and I'm wrong. I'm sorry. I'm not very familiar with the 2.5. All I know is that they are BASED on the 2.3 which I know well.
Dave R
In the snow belt
Kaiser
Yeah, call them back and ask for somebody who understands EDIS systems. The cam position sensor isn't even on the cam and actually has nothing to do with the cam. Yes, it's strange but true.
offroadranger
thanks guys
OK, thanks guys I'll call them back and see what they say, maybe try esslinger too......
so....anyone remember what to drill that maf tube out too for the 19lb injectors? :dntknw:
TireIron
Methuen, MA
does the 99 have the plastic MAF? That may be different as so far everyone who has done the larger injectors is using the older aluminum MAF housing... I dont know how much different the inside of the plastic housing is compared to the older aluminum housing. For the older ranger aluminum housing it was cut out the post and drill the sampling tube to 15/32". That is for the aluminum MAF housing from a ranger around the 93-94 era.
offroadranger
Mine is aluminum as well.....but the only "post" I see is what holds the actual sensor and tube in place.....we ARE talking about drilling the tube that the actual sensor wire is directly behind right?
Also, one more quicky - the 2.5 is just about the only engine running the 14lbers right? So if I have a 92 3.0 in my garage, those injectors should be 19lb?
Thank you guys so much for your help. This is the ONLY place I have found with such info....:icon_cheers:
Dave R
In the snow belt
Kaiser
Yes, you want to drill out the sampling tube and remove the post. BUT, be sure to remove the sensor from the housing first!
Not sure what injectors they used in the V6's most guys get their injectors from 4.6 Crown Vic's. (I think)
TireIron
Methuen, MA
a lot of the 4.0L had the 19 lbs, and tons and tons of 5.0L have them. I'd say go for a late 80s early 90s 5.0L and just pop one out and check the color of it.
offroadranger
What color am i looking for?
Zer0PSI
4
Johnson City, TN
2.3
Hope this helps!
ford injectors
19lb - orange
24lb - light blue
30lb - red
36lb - dark blue
42lb - lime green
