So I find no vac leaks, cleaned everything still no positive results. When I first start the engine it will idle high then go down but still above normal idle when I put it into reverse it hesitates as it revs then it goes into reverse when I shifted into drive it will rev and then go into gear normally. When I turn the air conditioner on the engine revs also when I first take off in drive it holds first gear for a really long time it seems that after that it ships normally. Also the four-wheel drive is not working like it won't turn on.
